GT shocks and struts an upgrade?
Old 07-10-2010, 01:35 PM
staggolee
staggolee's Avatar
Default GT shocks and struts an upgrade?
Hey I was looking to (finally) upgrade the suspension on my 6er and am looking at all the products on newtakeoff. I see there is a package that comes with both sways as well as all the shocks and struts off a GT.
I really want the swaybars, I know how much of a difference they can make. But are GT shocks and struts on my car worth the extra cash as an upgrade over my stock parts.
Here's the link to the product: http://www.newtakeoff.com/mustang_gt...2005-2008.aspx
Thanks guys
staggolee is offline
Old 07-11-2010, 08:46 AM
allinon72
allinon72's Avatar
No reason to purchase that when you get get the GT500 stuff for $175. It's an unbeatable deal:
http://cgi.ebay.com/ebaymotors/05-11...Q5fAccessories
allinon72 is offline
Old 07-11-2010, 09:30 AM
Twstones
Twstones's Avatar
I keep looking at this too, only for the ragtop. Has anyone here put this kit on? How much difference does it make over the v-6 set-up? The GT500 suiff also lowers the car, will the alignment need to be adjusted?
Twstones is offline
Old 07-11-2010, 12:12 PM
staggolee
staggolee's Avatar
oh cool, thanks for the link, allinon. But twstones is right, what kind of extra work needs to be done if I install the GT500 parts. Also I just saw that it doesn't come with a rear sway bar and instead comes with a strut tower brace, which I don't think will fit my V6
Old 06-12-2011, 04:11 PM
asl9622
asl9622's Avatar
I am also curious as to if this upgrade is worth it on a base v6 automatic 2007 ford mustang. Any ideas?
asl9622 is offline
Old 06-12-2011, 05:02 PM
aaquib1992
aaquib1992's Avatar
I don't think the shocks/struts are changed very much (in terms of compression/rebound) for the GT than the v6, but I do know that the springs for GT's are harder (to compensate for more weight) therefore I would imagine the shocks/struts are slightly changed to handle the different spring type...
I doubt its gonna be a huge difference, other than stiffer handling and harsher ride quality IMO. Might just want to go aftermarket for those, or get those GT500 parts .
As far as I know, the sway bars (gt500 or GT) will fit the v6 no problem, but to add the GT500 shocks/struts you need new upper strut mounts for them...
aaquib1992 is offline
Old 06-12-2011, 11:14 PM
67stangr
67stangr's Avatar
Your car will sit a bit higher since the gt is heavier, you prob dont want to look like a 4x4.
67stangr is offline
Old 06-12-2011, 11:53 PM
SamsBlueGT
SamsBlueGT's Avatar
Correct me if I'm wrong, but I thought the only thing that will make your car sit higher/lower would be springs, he's looking at shocks/struts.
SamsBlueGT is offline
Old 06-13-2011, 09:31 PM
67stangr
67stangr's Avatar
true just the springs will lift the car. sorry i was tired when i wrote that. and the shocks and struts i want to say are the same for v6 and gt.?
67stangr is offline
Old 06-13-2011, 10:01 PM
Alec
Alec's Avatar
I have a GT500 STB on mine
Alec is offline
Quick Reply: GT shocks and struts an upgrade?
