Does a standard 4 wheel alignment usually include panhard adjustment?
Old 03-10-2011, 09:28 AM
starbai
starbai's Avatar
Default Does a standard 4 wheel alignment usually include panhard adjustment?
Hey folks...
I'm considering doing the cheap route as a temporary fix for my need for being lower.
Cheap in that I'm considering only doing Springs and adj panhard bar FOR NOW.
I know its gonna ride like crap, but assuming I am pretty sure given my previous cars that I can live with it like this for a few months.
Anyway. I'm pretty sure I can handle the spring install myself. And I'm also fairly certain I can handle the panhard bar install myself as well on my back with the car on jack stands.
The question is once that pan hard bar is in, how the heck do I adjust it?
I've got a 3 year warranty alignment with my previous car at a local tire shop, I'm allowed to transfer that warranty to another car ONCE during the life of the warranty. I plan on transferring it to the Mustang, and not having to pay for an alignment for it but getting one done.
Does the tire shop, doing a routine 4 wheel alignment routinely adjust panhard bars as part of the whole alignment process? or do they just adjust camber/toe/caster typically?
Thanks for your guidance fellahs.
starbai is offline
Old 03-10-2011, 10:52 AM
danzcool
danzcool's Avatar
Yes., but you sometimes have to remind them that it is adjustable.
danzcool is offline
Old 03-10-2011, 01:20 PM
partsbill
partsbill's Avatar
routinely no, the pan hard bar as nothing to do with a 4 wheel alignment, it just recenters the body over the axle, if you were to ask them to they probably would, but routinely I'm pretty sure they wouldn't.
partsbill is offline
Old 03-10-2011, 01:31 PM
starbai
starbai's Avatar
I know the shop well and the guy in particualr that usually works on it probably wont mind doing it. How precise is this? In other words, is adjusting it something that I could easily do? Do they need any kind of particular measuring equipment to ensure its as dead center as possible?
starbai is offline
Old 03-10-2011, 01:33 PM
MrLatte
MrLatte's Avatar
Is your adjustable panhard bar ON-CAR adjustable? That would make it a lot easier.
Here's an on-car adjustable UMI panhard bar from Sam Strano that I've had my eye on:
http://www.stranoparts.com/partdetai...208&ModelID=35
MrLatte is offline
Old 03-10-2011, 02:12 PM
starbai
starbai's Avatar
Haven't picked on yet... though I'm highly considering the Steeda Adjustible one.
http://www.steeda.com/store/steeda-a...d-mustang.html
starbai is offline
Old 03-10-2011, 03:33 PM
partsbill
partsbill's Avatar
I went with the Steeda also.
Attached Thumbnails Does a standard 4 wheel alignment usually include panhard adjustment?-006-1.jpg
Old 03-10-2011, 03:36 PM
starbai
starbai's Avatar
Just for the record and future reference, it seems like the steeda IS on car adjustable as well...
According to this:
https://mustangforums.com/forum/2005...on-w-pics.html
starbai is offline
Old 03-10-2011, 04:10 PM
danzcool
danzcool's Avatar
I believe the adjustable pan hard bar adjusts thrust angle (dog tracking) which IS one of the measurements of a 4-wheel alignment.
danzcool is offline
Old 03-10-2011, 06:50 PM
Norm Peterson
Norm Peterson's Avatar
If it affects thrust angle, it's only indirectly and only by a very little. Shifting the axle laterally theoretically does shift the thrust angle because the two LCAs are not quite parallel to each other or to the car centerline.
It would be far easier to make thrust angle changes with adjustable-length LCAs.
FWIW, you should never be paying 4-wheel alignment prices for a stick-axle car. Thrust angle alignment price tops.
Tweaking stick axle alignment other than thrust angle is pretty serious road-race or autocross stuff, and for any shop that would actually have the capability and the time to do it and the expertise to do it right, I doubt that standard alignment shop 4-wheel alignment money would be enough to get your car even looked at.
Norm
Norm Peterson is offline
Quick Reply: Does a standard 4 wheel alignment usually include panhard adjustment?
