FAYS2 watts link with Roush Stage 3 rear sway bar ?
Old 08-03-2012, 10:29 PM
JAJ
JAJ's Avatar
Originally Posted by AutoXRacer
Has anyone installed one of these lately? I am having issues adjusting my rods and setting it up. My first question is: Are your rods parallel to the ground and axle when the vehicle is on the ground or are they inverted “V” shaped?
The only way my rods are parallel to the ground and axle is if the rear end is lifted about 1” before hitting the bump stops onto the frame.
Your brackets need to rotate to lower the end links enough that the driver's side rod end doesn't hit the over-axle exhaust pipe. Depending on the ride height, you'll have some angle on the arms. So long as the angles are equal and opposite, the system will perform correctly.
JAJ is offline
Old 08-03-2012, 10:43 PM
AutoXRacer
AutoXRacer's Avatar
Thanks, I have no issues with contacting the exhaust or anything like that...just want to make sure my configuration is correct.
Thanks for all the help guys.
AutoXRacer is offline
bjdutch2005
03-24-2017 03:38 AM
Dragonus18
09-09-2015 01:21 AM
RWHEELS
09-05-2015 03:42 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: FAYS2 watts link with Roush Stage 3 rear sway bar ?
