Understeer question - Page 2 - MustangForums.com
Old 05-04-2011, 07:42 AM   #11
Norm Peterson
Norm Peterson's Avatar
Cornering technique should come first, as that will affect what parts or tuning that you follow up with. Or maybe whether you even need to do anything at all. If you've ever played ball (or golf, for that matter), trying too hard to hit the long ball is lots more likely to end up with poor results than when you take just a little off of it and let the timing of your swing do the work. Maybe think of "overdriving" as being the motorsports equivalent of "overswinging".
Then play with the tire pressures a little.
A stiffer rear bar will reduce mid-corner understeer, and a sixxer will generally be a little more tolerant of too much rear bar than a GT would be. But it still won't be a lot of help if you've overdriven the fronts all the way into heavy/plowing/sliding understeer. Flip side is that it can make it a little harder to add throttle on corner exit - you won't be able to put quite as much power down until you're going straighter. If you're already on occasion getting the rear end loose with the throttle coming off the corners or getting RR wheelspin coming out of righthanders, a stiffer rear bar is going to be kind of a "be careful what you ask for" mod.
Norm
Norm Peterson is offline   Reply With Quote
Old 05-04-2011, 08:52 AM   #12
Sleeper_08
Sleeper_08's Avatar
Norm
My track setup is per my sig and last season i was running 39 pounds front and rear in the NT01s.
The car feels pretty good to my somewhat less than sensitive posterior and generally I am happy with the handling. The one noticeable problem I have is a very slow speed right hander where the slow in out fast technique has helped reduce the oversteer and excessive wear on the left front.
The corner starts at about 1:00 in this video;
http://mustangforums.com/forum/s197-...ml#post7532574
What would you suggest I try with the hot tire pressures allowing for the extra weight on the front of my SC.
Sleeper_08 is offline   Reply With Quote
Old 05-04-2011, 09:04 PM   #13
MustangFirstCar
MustangFirstCar's Avatar
Norm
The only time I get wheelspin when turning is when I peel out and fishtail from a stop sign, lol. My car is not nearly powerful enough to do that kind of stuff.
It seems obvious to me that I should just go out an work on technique. That is all just fine I guess, because I would rather save my money for now.
So does anybody know how STR.Ts might affect cornering?
MustangFirstCar is offline   Reply With Quote
Old 05-06-2011, 11:10 PM   #14
SlideWRX
Quote:
Originally Posted by azrampage View Post
Yes, you have most of the GT suspension. Same front sway bar (34mm), very similar springs, and a slightly smaller rear sway bar.
On the cheap:
If the rear is slightly smaller, I'd definitely go for the GT bar. look for someone who is getting rid of the stock hardware after upgrading. Get stiffer bushings for the rear bar as well.
do your own alignment to make sure you are close to zero toe in the front. If you have no idea, go find some local auto-x guys. You can get a pretty darn accurate toe alignment by yourself. If you play with the camber, do that first.
Definitely play with tire pressures. If you are running normal tire pressures, increase the front in 2 psi steps. I'll bet 36ish would be great for grip.
SlideWRX is offline   Reply With Quote
Old 05-10-2011, 04:51 PM   #15
azrampage
azrampage's Avatar
Quote:
Originally Posted by SlideWRX View Post
On the cheap:
V-6 rear sway bar = 18mm; V-8 = 20mm. Agree, get the GT rear.
Zero front toe = good. Make toe plates to set easily.
Tire pressures on stock Pirellis: I autocrossed on 42# front and rear; maybe not good for daily driving.
azrampage is offline   Reply With Quote
Old 05-10-2011, 07:25 PM   #16
MustangFirstCar
Would there be a benefit in going with a thicker rear sway then 20mm? If so, about how thick would a sway bar have to be before it started hurting performance?
Old 05-13-2011, 01:36 PM   #17
Norm Peterson
I'd get a 20mm GT take-off and drive around with it for a while - it's probably stiffer than you're thinking (it's about 50% stiffer than your 18mm Pony bar, not just the 10% or so that the diameter numbers might be suggesting to you).
Keep in mind that a neutral-ish setup that drives just fine on warm, dry roads can easily become "loose" when it's wet, cold, or worse. Since you mentioned not wanting to be twiddling with adjustments, you'll still want to retain some understeer for those conditions. Understeer has nothing on oversteer when it comes to suddenly getting your attention with visions of curbs, trees, utility poles, ditches, the end of the car that isn't connected to the steering wheel, hell, and handbaskets.
I would not expect the STRt's to shift the car's understeer/oversteer balance much (for that you'd look into staggered settings on the yellows). More like better composed and not quite as harsh especially in the rear. Get Sam Strano's thoughts.
Just happened to see something in the current issue of the SCCA's monthly magazine, written by the chief instructor for Bob Bondurant (and who has 27 years instructing experience at this point). "Easy in, fast out", with the thought that you ought to be able to start adding a tiny bit of throttle even before you get to the apex. A reasonable interpretation probably runs something like "If you can't do that every time on the street, you're doing something wrong".
Norm
Old 05-13-2011, 10:39 PM   #18
azrampage
azrampage's Avatar
Default Good Advice
Norm gives very good advice. You can take it to the bank.
Norm
Old 08-05-2012, 01:47 PM   #19
M3hunter
M3hunter's Avatar
Question
Sorry if I steep in.
I was reading this post, and I really see great knowledge about handling improvements. I have a future simillar issue. I have a GT Brembo with the Steeda Sport Springs and KONI STRT. My rear tires are almost wasted, and I was thinking if I could replace them with 275/35R19 or 275/40R19 on the stock brembo wheels. I think that this setup might bring understeer to my car, do you think that with a wider rear sway bar, this will bring back my car to a more neutral handling. I will like to improve the looks but without affecting the present handling, if posible it will be great to improve it.
Another doubt, is that, if you think that the car with the 3.73 gears (standard transmission) will behave strange with the 275/35R19 or 275/40R19, compared to the stock setup?
M3hunter is offline   Reply With Quote
Old 08-05-2012, 01:49 PM   #20
snicksnipa
snicksnipa's Avatar
+1 to adjustable sway bars, they can give you the perfect amount of oversteer at ease.
snicksnipa is offline   Reply With Quote
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 09:13 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 09:06 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 11:29 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
01, 1995, 2007, 2011, cornering, fine, ii, mustang, norm, package, peterson, pony, tuning, understear, understeer, v6
