Mild driveline whine after lowering
Old 07-17-2011, 08:55 AM
dan_h
dan_h's Avatar
Default Mild driveline whine after lowering
just wondering if anyone else noticed this...just lowered the car with Steeda Sport springs (mild drop) but now i have a slight (not annoying) whine at 75-80mph...sorta quiet, definitely sounds like it is coming from the driveline, not noticeable at lower speeds but constant on the highway....is this due to pinon angle change from the lowering?
Just wondering if i (now) need to also get an adjustable UCA to reset my pinon angle to eliminate it (???)
thanks,
dh
dan_h is offline
Old 07-18-2011, 05:24 AM
Norm Peterson
Norm Peterson's Avatar
Since you still have the OE LCAs and UCA, try loosening all six rear control arm bolts and settling the car by bouncing it and perhaps rolling it a few feet before retorquing them. You'll need ramps, because the retorquing must be done with the wheels fully loaded with the car weight. This will remove all or most of the stress that you put the bushings under when you lowered the car, which I think makes them transmit sound better (obviously not what you want here).
The noise itself was probably always there.
Norm
Norm Peterson is offline
Old 07-18-2011, 06:14 AM
2005Redfire6
2005Redfire6's Avatar
Sounds like gear whine and your pinion angle may be off from lowering, what Norm suggested should fix that issue...
2005Redfire6 is offline
Old 07-18-2011, 09:06 AM
BlackBetty
BlackBetty's Avatar
Just get a louder exhaust. Fixes all sorts of weird noises.
BlackBetty is offline
Old 07-18-2011, 09:49 PM
dan_h
dan_h's Avatar
For now I'll try out the first two recommendations . Louder exhaust will be my bandaid for later,
thanks guys,
dh
dan_h is offline
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
09-30-2015 12:39 PM
Quick Reply: Mild driveline whine after lowering
