Squeak when accelarating, bushings?
Same thing here... No squeak when stopped, or cornering for me. Only when accelerating at a significant pace (quarter/half? throttle or more)
If it's only happening on acceleration that's at least moderately hard, the first thing that comes to mind is that the engine torquing over has something to do with it. That results in exhaust line movements unlike any other commonly encountered situation. I suspect that revving in neutral is not rocking the engine enough.
Either something is sliding that normally doesn't as the engine torques over, or something is rubbing only after it has done so.
I think it is possible to have the clamp itself tight, but not the joint. When 200 ft-lbs of torque (or some multiple of that) says the engine, tranny, and exhaust are all rolling over just a tad, exhaust pipe clamp friction isn't going to stop whatever is left after the motor mounts have taken their share.
Something else to consider is thaat these clamps don't give you nearly enough leverage to close up a pipe that's just a little too big, or dented slightly out of round right at the joint. And quality control on more than a few aftermarket exhaust system parts/systems is . . . iffy.
Norm
Norm
ok it seems I fixed my problem..i ruled out my exhaust cause I checked it so many times..I just got some WD40 and sprayed all my poly bushings on my UMI lower control arms and panhard bar really good..nice saturation to make sure it creeped all in...i guess maybe there was a little bit of something in there making it chirp..i romped on it a few times tonight and now nothing but the sound of the exhaust.
Thanks for sharing man! Glad you got your squeak squared away.
When the noise shows up again (WD-40 is kind of a temporary fix, so I'm sure it will), try shooting only one bushing at a time until the noise stops (or starts to get quieter) so you'll know exactly which pivot or pivots it's coming from.
Norm
if it comes back..I am going to pull them off and reapply the Mobile 1 grease to the face of them again.
I didnt use WD40 I used Jig A Loo but I dont know if anyone would know what it was if i said that
http://www.jigaloo.com/us/e_products_jigaloo.php
I think I have the same problem.
http://youtu.be/FI9EQT885Ug This is a link to a video of my mustang noise... If you can verify your sound was the same I'd be forever grateful!
I have the same sound coming from my car ....
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
