Old 10-08-2015, 01:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
Steel Braided Brake Lines
Old 11-01-2011, 11:07 AM
devildog1679
devildog1679's Avatar
Goodridge has a new line of SS that have an outer coating to avoid dirt getting in between the SS and Teflon. It's there Phantom line. Tire rack has them. Pricier than the regular Goodridge SS but IMO safety has no price point.
Here they are
http://www.stillen.com/product.asp?i...&model=MUSTANG
devildog1679 is offline
Old 11-01-2011, 11:49 PM
Mustang Enthusiast
Mustang Enthusiast's Avatar
Originally Posted by Sleeper_08
I am running a set of Enkei PF01 18 x 9.5 x 35 mm offset wheels for track use.
They are very light for the price at about 21 lb. I bought them after careful consideration and research.
For road use you might want to get 45 mm offset as with the 35 mm offset the axle needs to be almost perfectly centered for the tires not to protrude slightly outside of the wheel well.
Thank you for the information on Enkei. I have done a lot of research with different brands of rims, mostly rims that are chrome plated that will be used for road use. These rims have a good structural warranty, but only have a 1 year warranty on the chrome plating. I found this to be an unacceptable warranty. That is when I came across Enkei, and found that I like the look, the materials they use, and their warranty. ENKEI wheels will be free from defects in materials and workmanship under normal and reasonable use. I have not called Discount Tire Co. to find out prices yet, but I am assuming they are going to be pricy.
Mustang Enthusiast is offline
Old 11-01-2011, 11:55 PM
Mustang Enthusiast
Originally Posted by devildog1679
Goodridge has a new line of SS that have an outer coating to avoid dirt getting in between the SS and Teflon. It's their Phantom line. Tire rack has them. Pricier than the regular Goodridge SS but IMO safety has no price point.
Here they are
Thanks for the information and the link. I will look into the Goodridge SS lines. I definitely agree that safety comes before price.
Old 11-02-2011, 01:32 PM
Sam Strano
Former Sponsor
Sam Strano's Avatar
I sell Goodridge, I sell Enkei.
You don't need to waste money on the "phantom" lines, the standard ones are sheathed. As for the Enkei's. I run them, and have a number of customers running PF-01's in both 9.5 and 10.5 widths (the latter sticks out a little and 9.5 are recommended for street cars). They are strong, light, and not super expensive. http://www.stranoparts.com/searchbym...222&ModelID=35
Sam Strano is offline
Old 11-03-2011, 01:49 AM
Mustang Enthusiast
Default Enkei
You mentioned you sell Enkei rims. Could you tell me if the Racing Series RP05 19x9.5 Special Brilliant Coating will fit a 2012 Mustang GT with or without a Brembo kit. Right now I don't have the Brembo kit, but would like to know in case in the future I decide to add the Brembo's. Right now I have the Ford Mustang 19 inch rim.
Thank you,
Don
Old 11-03-2011, 11:38 AM
Sam Strano
Former Sponsor
Sam Strano's Avatar
Well, what size? The way the spokes are on those, you might have an issue. I really can't say for sure, because with Brembo's it's about more than just offset, but also the spoke design.
Old 11-03-2011, 11:30 PM
Mustang Enthusiast
Default Enkei
The size would be 19x9.5 on all four rims. I am having a difficult time trying to find quality rims that will allow for a Brembo Kit. If I can't find any, then I will only upgrade the brake pads and possibly the rotors if they will fit. I also found on Enkei's web site that the RP05 rims are on closeout.
Old 11-04-2011, 05:11 AM
Sleeper_08
Sleeper_08's Avatar
The 18 x 9.5 x 35 PF01's fit the Brembos
Sleeper_08 is offline
Old 11-04-2011, 12:52 PM
Sam Strano
Former Sponsor
Sam Strano's Avatar
Most of us run 18" wheels, not 19's. You'd need to get a drawing from Enkei showing a cutaway view of the wheel and it's measurements vs. the hub face and compare that to a stock wheel. I suspect the RP05 would work, but I can't guarantee it.
67LimeCoupe
09-21-2015 06:34 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-16-2015 07:53 PM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
Quick Reply: Steel Braided Brake Lines
