2012 GT Is it worth the money to replace the sway bars
Old 10-26-2011, 10:27 PM
Pakman
Pakman's Avatar
Default 2012 GT Is it worth the money to replace the sway bars
Please help?
Pakman is offline
Old 10-27-2011, 08:41 AM
tj@steeda's Avatar
If you are looking to improve your handling then it is one step in the process to achieve that goal.
The rear swaybar will increase roll stiffness for balanced handling, improved steering response, elimination of understeer and noticeably improved balance.
Product Benefits-Adjustable Rear Sway Bar
3 Position adjustablity
Competition level proven handling performance
Improves steering response and eliminates understeer
http://www.steeda.com/store/ford-mus...r-swaybar.html
Non adjustable:
Direct bolt on replacement
Front Sway Bar:
http://www.steeda.com/store/steeda-a...d-mustang.html
tj@steeda is offline
Old 10-27-2011, 09:09 AM
SteedaGus
Former Sponsor
SteedaGus's Avatar
To expand on what was said above, As part of a project for handling improvement... yes.
As recommended above use part number 555-1070 for the front bar, and the 555-1073 bar linked above.
I dont know if you have a Brembo brake equipped car or not, if you do the Brembo cars have a bigger rear swaybar than the non-brembo GT, the 555-1073 adjustable rear bar will be an upgrade regardless of which one you have. That is why I recommend it.
SteedaGus is offline
Old 10-29-2011, 09:30 AM
eolson
eolson's Avatar
Good to see you posting Gus, thanks for all the help in the past. Erik Olson
It seems to me since the major shortcoming on the 2011 Mustang, in the Mustang - M3 track comparison, was the Mustang's shocks, that going with better adjustable after market shocks as well as Steeda Comp springs and adjustable front and rear sway bars would be the most direct no regrets decision with the 2011-2012 Mustang GT.. Erik
eolson is offline
Old 10-30-2011, 08:25 AM
Pakman
Pakman's Avatar
Thanks guy for the feedback. If I have a convertible GT does it require a different size sway bar?
Pakman is offline
Old 10-31-2011, 11:11 AM
SteedaGus
Former Sponsor
SteedaGus's Avatar
Hey Erik!! Good to see you. Thanks for your past business!
Depends on how far you want to take the car. If you are serious about handling the shocks and springs together should always be a priority.
Our normal sport springs and shocks would work just fine, the street/comp springs would be the next level and still capable of daily driving if paired with the adjustable shocks and struts.
Either combo along with front and rear swaybars would be a great handling combination.
Old 10-31-2011, 11:12 AM
SteedaGus
Former Sponsor
SteedaGus's Avatar
If you have a convertible you can use our 555-1057 1" rear bar or the 555-1073 1 1/4" adjustable rear bar.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
squishbang
09-07-2015 07:57 PM
09-01-2015 08:16 PM
mungodrums
08-29-2015 12:53 PM
Mobiusone stang
08-24-2015 04:08 PM
Quick Reply: 2012 GT Is it worth the money to replace the sway bars
