Koni str-t's or yellows?
Old 11-24-2011, 10:01 AM
Southern Stang 722
Southern Stang 722's Avatar
Default Koni str-t's or yellows?
I've been eyeing both of these for a while now but wondering whether I should go ahead and spend the money on adjustable or not. The car is daily driven here in south florida.
Sees the strip all the time, But I'm also a pretty agressive corner carver around town when traffic and streets allow. I'm lowered on frpp k's right now and planning on maximum motorsports CC plates to get everything back in line once I put shocks and struts on. I aligned it and toe is fine.
The car will see the road course soon and light autox here and there. I like the way it handles with just the springs but looking to add to that.
I'm just wondering if I should go ahead and spend the money on the yellows for the ability to adjust or not. Thanks for the help guys!
Southern Stang 722 is offline
Old 11-24-2011, 10:12 AM
Norm Peterson
Norm Peterson's Avatar
For the variety of uses you mention and the list of things in you sig, I'd say go for the yellows.
Autocrossing, road course lapping, dragstrip runs, good streets, and expansion-jointed concrete can all benefit from different settings. Especially those last two settings if you're apt to have passenger(s) aboard who are are more sensitive to ride quality when driving over bad pavement.
Norm
Norm Peterson is offline
Old 11-24-2011, 12:06 PM
07BLACKGT
07BLACKGT's Avatar
Yellows! I love playing with the adjustability. Full soft rides so nice, but I run them a bit firmer just for taking corners around town. Handles amazingly.
07BLACKGT is offline
Old 11-24-2011, 09:27 PM
devildog1679
devildog1679's Avatar
How hard or easy to adjust them? Front and rear?
devildog1679 is offline
Old 11-24-2011, 09:34 PM
Sleeper_08
Sleeper_08's Avatar
Five minutes to adjust all 4.
I don't have the 1000 Watt sound system.
Sleeper_08 is offline
Old 11-25-2011, 02:01 AM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
I love my yellows.
Been on for a couple hundred mile and the difference is insane.
MELLOWYELLOW06 is offline
Old 11-25-2011, 08:41 AM
Norm Peterson
Very easy (unless you've got the trunk full of stuff).
I also found that you can make a much more durable adjusting tool that's also a lot easier to repeat settings with. Just a short piece of steel with slots cut for the little adjusters. IIRC, the front and rear adjusters seemed to be slightly different thickness (didn't bother measuring, just cut the slots and filed to fit).
Norm
Old 11-25-2011, 09:20 AM
Norm Peterson
In use.
It took longer to upload the picture than it would take to open the hood, adjust both front shocks, and close the hood again. Rears take slightly longer.
Norm
Old 11-25-2011, 09:31 AM
devildog1679
Originally Posted by Norm Peterson
In use.
Norm
I thought i read that you had to take the rears off in order to adjust. Since that's not the case I may skip the str.t and wait for the yellows. Wish i could locate a set now
Are these the same? http://www.281motorsports.com/produc...oducts_id=1733
Old 11-25-2011, 09:41 AM
Norm Peterson
Years ago with Koni's adjustable "Reds", you did have to disconnect one end so that you could bottom the piston in the shock and get some sort of internal adjusting mechanism to move from one 'step' to another. Only 3 discrete steps to choose from.
The Yellows are a completely different animal (continuously adjustable) and you'll probably be able to feel the difference that 1/8 turn makes.
Norm
Quick Reply: Koni str-t's or yellows?
