Help with sway bars
Help with sway bars
I had a 2010 GT before the 2012 and thought the 2010 handled noticeably better. I drive spirited but not hard. Car stays on the streets, no tracks. I put the FRPP 1" lowering springs and dampers on but am still on stock sway bars. Will I notice a difference with bigger sway bars? Would you go with Ford or other bars? Thanks for your help.
You will notice improved handling with a sway bar. Regardless of track use or street use you will notice added benefits.
Steeda Front Swaybars withstand the rigors of high performance racing while providing the performance and handling benefits you want without degrading ride quality for street use.
http://www.steeda.com/store/steeda-a...d-mustang.html
If you want to go with both front and rear swaybars for ultimate performance, then that is an option too.
You will only see benefits and no real drawbacks for going with a sway bar.
Hope this helps
Thanks
TJ
Hope this helps
Thanks
TJ
I'm happy to help. I carry lots of choices on bars, beyond my own I also have Steeda, Eibach, Progress, Hellwig, Hotchkis, and H&R. I don't think you'll find any one person or company that carries more variety....
That said, I do take the effort and cost to make my own set, because I wanted some specific sizes and options to work in various situations.
While true in the most basic sense, that doesn't always mean bigger is better. In fact one of the first changes I made to my 2011 when I could legally do it (in the classes I was competing in) was to go back to a 22m adjustable rear bar from the stock 24 solid, non-adjustable. I already had a bigger front and different springs. I think the 24mm rear bar is no bad on a standard car, it's a bit too much rear on a Brembo car (with the springs they use) and all the other stock components.
I wish I could go back in time and have someone with racing experience fit out my suspension and actually drive the car hard and keep adjusting for a few days until it was right, when I first fit out my car.
I think there is no question in order to not have to re-buy parts after an initial "best guess" beginning fit out, is to initially go with tried and true 1" drop linear rate performance springs like Steeda's or Ford's, and going with the Koni adjustable sports dampers gives you all the performance quality and adjustability you'd ever need.
Having just the right adjustable sway bars put on and adjusted as the car is tested for hard cornering and cornering and accelerating out of corners is invaluable by an experienced driver.
I would also suggest lowering the engines center of gravity 1/2" with high performance engine mounts, in combination with lighter wheels and wider better rubber.
If I had to do it over again, for handling, all the above is what I would insist on, Erik
09-16-2015 07:53 PM
