Koni Yellow Adjustments
#21
I ran my koni's at two full turns on all four corners last weekend and had no issues at all. The car responded perfectly. For daily driving it run them all full soft since I have to drive over a lot of speed bumps. Thanks for all the advice.
#25
[QUOTE=JAJ;7815982]
They are hyperco 2.5" coilover springs (8" up front and 10" in the rear). I got my Konis from Sam and used the Ground Control coilover conversion kit that I had been running on my Tokicos.
Very true. Honestly on the road course I didn't notice a difference in times--the Tokicos aren't a bad damper by any means. But...on the street is where I really like the Konis more. My local roads are awful. Not potholed, chopped up awful like I used to see on the East coast, but instead lots of higher frequency sharp bumps that were hell with the Tokicos--I just couldn't find the sweet spot given how the rebound and compression is coupled.
Now, these stretches of road still suck (can only do so much with the live axle), but the Konis have really taken the edge off.
#26
Wonderful - thanks for the explanation! Do you have to remove the spring seats (cut and grind) from the Koni's to install Jay's conversion kit?
#27
