Lowered + staggered tires + wheel spacer = rub??
Old 02-04-2012, 02:38 PM
Rylay
Rylay's Avatar
Default Lowered + staggered tires + wheel spacer = rub??
she's stock right now and I want to lower her about 1.3-1.4" or not very much and get some staggered 10" wide tires 18" and maybe some wheel spacers.
now i understand that this is probably overkill but i want that really low and wide look because there's this pesky corvette on my way to work that i keep getting stuck behind and I'm getting a little envious.
my main concern is rubbing so if someone could recommend some really stiff lowering springs which don't have to lower it more than an inch (its not a big concern). I plan on sticking out a little but the spacer might be a little too much on top of the staggered tires.
Also if some wheel designs stick out more than others, can someone edjumakate me on that too. thanks
Rylay is offline
Old 02-07-2012, 04:09 PM
DRock
DRock's Avatar
If you want that low wide and stiff look then you need coilovers
DRock is offline
Old 02-08-2012, 11:46 PM
Rylay
Rylay's Avatar
mmk added um to my list. Are those in addition to the other stuff? And could you recommend a brand?
Rylay is offline
Old 02-08-2012, 11:52 PM
Rylay
Rylay's Avatar
I've also said no to the spacers just cause of peace of mind...still lookin for the fat rear end though
Rylay is offline
Old 02-09-2012, 12:41 AM
07BLACKGT
07BLACKGT's Avatar
Yeah good call on dropping the spacers.. they won't be needed. The staggered 18's will sit flush with the fenders if you are low enough.
This is my buddy's car on Sportline springs and 18x10 out back.
As you can see, no spacers needed here
I just put a mild drop on mine (Steeda Sports). It has a mean as hell stance from behind with the 18x10.5" out back, so all you really need are the rims/fat *** tires and springs. (and a set of dampers if you want it to handle and ride smooth).
07BLACKGT is offline
Old 02-09-2012, 09:42 AM
D'prived
D'prived's Avatar
No spacers... FRPP K springs, 1.5" drop both front and back with Tokico adjustable shocks/struts. 18x10's rear and 18x9's front.
D'prived is offline
Old 02-09-2012, 12:13 PM
DRock
DRock's Avatar
Thats not flush. Needs atleast a 10mm spacer out back. Im lower than sportlines anyways too lol
DRock is offline
Old 02-10-2012, 10:21 AM
Rylay
Rylay's Avatar
I'm going with d'prived on this one cause I've always loved your car.
Rylay is offline
Old 02-11-2012, 10:08 PM
D'prived
D'prived's Avatar
Thanks! Good choice!
D'prived is offline
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
GentleBen
09-11-2015 05:34 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: Lowered + staggered tires + wheel spacer = rub??
