Sway bar Options
Old 02-14-2012, 09:07 AM
devildog1679
devildog1679's Avatar
Default Sway bar Options
Next month I’m installing Koni Yellow’s, Steeda Sports, and more than likely BMR upper and lower control arm’s. The last piece missing are the sways and I see many options out there. I believe I have narrowed it down to three main choices. Hotchkis, Steeda, or Strano B3 package. This is how I see it
HotcchkisCould be overkill with a 38MM front bar though it is tubular so it may not be as stiff as a solid 38MM and it’s 4 way adjustable. Rear bar is 25MM, tubular and 3 way adjustable. At $540 it’s the priciest option but it may be due to the fact that all the bushing brackets are greasable. I like this since I don’t have to remove to grease.
http://www.stranoparts.com/partdetai...200&ModelID=35
SteedaFront bar is 35MM, tubular and 3 way adjustable, rear bar is 25MM solid and 3 way adjustable. Rear bar comes with endlinks and new bushings, the Front uses stock hardware. At $449 it’s the middle of the pack. To add greasable bushings to the front (I believe their rears are geasable) would be $89 for UMI bringing total to $538.
http://www.steeda.com/store/steeda-a...d-mustang.html
Strano B3Front bar is 35MM, tubular and 3 way adjustable, rear bar is 25MM tubular and 3 way adjustable. Comes with all mounting hardware but the bushing brackets are not greasable. Though at $359 it’s the most economical and knowing Sam’s reputation I’m sure it’s great quality.
To add greasable bushings (Hotchkis rear, UMI front) to both front and rear would cost about $239 bringing total to $598.
Bushings
http://www.hotchkis.net/heavy_duty_b..._brackets.html
devildog1679 is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
Quick Reply: Sway bar Options
