how much superblue do i need?
as per most of yalls suggestions im planning on getting some ATE super blue. since im switching from DOT 3, do i need more than the 1 litre that it comes with? i know you have to keep flushing to get rid of all the old stuff, i just have no idea how much itll take. thanks!
No, reserve the alcohol flush is for yourself after the job is done. DOT 3 and DOT 4 are fully compatible, so just a regular flush will suffice. It's best to do it twice, spread out over a week or so with a few hard stops in between to engage the ABS, to make sure it's complete.
I believe the system takes about 1.5 pints. That's what the Ford documentation says. I usually open and use a liter of fluid.
We usually use over 1 litre to do a full flush but tend to err on the make sure all of the old fluid is out side.
MSR houston, i dont think its too bad on the brakes. thanks for the info!
