Rear sway bar differences 05 / 11?
I'm looking for a rear sway bar for my 2012 V6. I see the part numbers sometimes vary between the 05-10 and the 11-12's. Will a sway bar for a 2005 GT fit on a 2012 V6? Reason I ask is Steeda makes a rear sway for the 05-09 that works with the original endlinks, but the only 11-12 version comes with endlinks I don't want and doubles the price.
555-1071 has endlinks, because it requires them. Stock endlinks would not fit. Whereas stock endlinks will fit on the 555-1056.
Aside from the myriad of Steeda bars (some of which like their adjustable which is WAY too big), I also have my bars. I make a tubular rear that is 1" diameter and 3-position adjustable as well. It's a thin wall tubing, at full soft it's similar to a heavier solid 7/8" rear bar, at full stiff it's more like a solid 1" bar.
That bar is direct bolt-on, and come with new hangers (the rear doesn't have endlinks no matter what they are called on anyone's site... they aren't at the ends, and they mount the bar to the car. Completely different to front endlinks).
The V-6 has a 22mm solid rear bar on it. So like Brandon stated it's not worth putting another one of those on the car. And yes, I sell all the Steeda bars as well as my own.
As I understand it the base car has a 22, the PP has the GT's 24mm rear bar. Floppy as hell can also be the shocks... rebound damping controls the rate of the roll. You can control the rate (slow it down) or the amount (lessen it), or both. There is a bar back there, I'm sure. Older V-6's that were not Pony Package cars or convertibles did NOT have a rear bar at all. Pony's and converts had 18mm rears in the older body style.
thanks for the info.
11-10-2015 11:39 AM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
