First suspension upgrades - MustangForums.com
Old 05-02-2012, 08:38 AM   #1
2008Vert
Default First suspension upgrades
I have an 08 V6 Base convertible.
http://www.newtakeoff.com/mustang_gt...2005-2009.aspx
I found this kit for the GT convertible. Would this be a major improvement over what I have?
I would like to start doing some mods and thought this might be a good start.
And would it fit?
2008Vert is offline   Reply With Quote
Old 05-02-2012, 08:52 AM   #2
Warpig12354
Maybe the sway bars would be an upgrade but everything else would probably not be noticeable. I would go with the Koni STR.T's (on sale right now) and a set of Steeda sport springs if you want to see and feel a noticeable difference.
Warpig12354 is offline   Reply With Quote
Old 05-02-2012, 09:18 AM   #3
safetyfastgt
safetyfastgt's Avatar
Steeda now has sport springs specifically for convertibles, that deal with the extra weight in the rear of a convertible.
safetyfastgt is offline   Reply With Quote
Old 05-02-2012, 04:08 PM   #4
tj@steeda's Avatar
2008 Vert,
We definately have the ability to get you to your goal of a better ride. Is this your DD and what are you looking for in regards to improvement?
Shoot me a PM and we can start looking at packages that fit your needs. Steeda is an American Made company that specializes in Ford vehicles.
Let me know your thoughts.
Best Regards,
TJ
tj@steeda is offline   Reply With Quote
Old 05-03-2012, 12:27 AM   #5
UPRSharad
Sponsor
UPRSharad's Avatar
And would it fit?
That would be an improvement over your stock stuff, but to me, if I was going to replace the factory suspension, I'd go for more performance oriented equipment.
That said, I like lowering springs, an adjustable panhard bar, and rear control arms as a good place to start modding the suspension. And of course, we carry all of these at www.uprproducts.com. Also, our parts are Made in America, they carry a Lifetime Guarantee, and mf.com members get a 10% discount on any part we manufacture.
UPRSharad is offline   Reply With Quote
Old 05-03-2012, 10:00 AM   #6
imaredtuna
imaredtuna's Avatar
I'd start with Konis before anything else.
imaredtuna is offline   Reply With Quote
Old 05-04-2012, 01:46 AM   #7
2008Vert
Can anyone tell me what size the sway bars are on my base convertible and what size the ones on a GT convertible are?
Also, what is the difference between the suspension on the vert and the suspension on the coupe?
Old 05-04-2012, 02:44 AM   #8
Forty-two
I am currently in the same situation of improving my suspension and I've been reading a lot. In the end I chose Koni Sports (Yellows) and Steeda Sport Springs as my first step. In addition I will put in camber plates by Maximum Motorsports. Still waiting for the springs to arrive so I can put them in
Quote:
Is there a huge difference in the springs for the coupe and those for the convertible?
GT convertible should have 34mm/18mm, the V6 convertible 31.7mm/18mm. That's the info I could find. I didn't measure mine though
Forty-two is offline   Reply With Quote
Old 05-04-2012, 08:51 AM   #9
2008Vert
So the rear swaybar on both the base and the GT are the same? The only differenct being the front?
I have been reading up on it and it would appear that the Pony Package V6 is the same setup as the GT?
I have also read that the Pony Package may actually have better handling characteristics than the GT because of the decrease in weight of the V6 over the V8?
I guess what I am getting at is that now I have the stock base convertible. I have found a complete (springs and all) GT convertible suspension including the strut brace for 300 bucks locally. It would seem that that would be a major improvement over what I have and a good place to start. I just bought the car so I probably won't be doing any serious performance mods for a while.
Thanks to the guys from Steeda and UPR but I just don't have the budget for much right now.
Old 05-07-2012, 02:46 AM   #10
Forty-two
That's what I've read, too. Pony Package should be the same as the GT. I'm not sure though if both convertibles (Base & GT) have the same sway bars. Been reading the GT is a lot stiffer, so maybe only the diameter is the same, but the material different?
Upgraded PaulH2 Members Rides and Car Show Section 20 01-31-2016 10:48 AM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict Lethal Performance 0 10-01-2015 09:58 AM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict 3.7L V6 S550 Tech 0 10-01-2015 09:57 AM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
Car Suspension problems? marc954 4.6L (1996-2004 Modular) Mustang 2 09-29-2015 12:18 PM
0509, 06, 2005, 2008, 2011, convertable, convertible, front, lowering, mustang, sn95, springs, steeda, suspension, upgrade, upgrades, v6
