Suspension noob looking to upgrade
Old 06-01-2012, 07:13 AM
Norm Peterson
Norm Peterson's Avatar
Putting the adjustment where it's easier/easiest to get at may not be the best place from a structural point of view.
For the number of times that you're likely to ever adjust it after getting it set the first time, I wouldn't even bother with having on-car adjustability. For those who see an air ride system or frequent spring changes after the first one in the future, on-car adjustability may be worth it.
Norm
Norm Peterson is offline
Old 06-01-2012, 07:44 AM
Rylay
Rylay's Avatar
You missed the part where my car was up on my lift
I'll do it the way it's suppose to be.
Rylay is offline
Old 06-01-2012, 08:41 AM
Whiskey11
Whiskey11's Avatar
FWIW not all PHBs are created equal. Like everything in life you get what you pay for. I would look into Steeda, BMR, UMI, Maximum Motorsports or Freedom Racing as they are KNOWN quality pieces with quality welds, the proper hardware and quality bushings which leads to a longer lasting piece. I would also take a look specifically at the ones with zerk fittings for the poly bushings to ease lubrication but it isn't necessary just convenient.
Whiskey11 is offline
Old 06-01-2012, 09:37 AM
Rylay
Rylay's Avatar
Duely noted, but the phb is going to be where I make cost effective cuts. (as opposed to the struts/shocks springs and mounts anyway)
Rylay is offline
Old 06-01-2012, 09:38 AM
Rylay
Rylay's Avatar
Come to think of it my phb only has around 3k miles on it, think anyone would buy it?
Rylay is offline
Old 06-01-2012, 11:06 AM
Whiskey11
Whiskey11's Avatar
I kept all of my stock parts in case I ever go back to stock... would someone buy it? Maybe a V6 owner with the rest of the GT suspension but I wouldn't think so.
Old 06-01-2012, 11:30 AM
Rylay
Rylay's Avatar
Or anyone who slides drivers side into a curb...
Rylay is offline
Old 06-06-2012, 10:09 AM
SteedaBrandon
Former Sponsor
SteedaBrandon's Avatar
I had my car up on my lift and I was poking things and drinking martinis and other things that people do under cars and I noticed a dark spot at the rim of one of the rear struts. I took it off and it had a pretty inconsistent rate and a gurgle-e noise so I thought instead of paying ford oodles of cash for an oe replacement,(why the hell are shocks a wear item, they should last forever!) I would splurge a little and buy some performance struts/shocks and lowering springs. (only looking for an inch or so as far as drop).
But as the title says, I don't know a whole lot on the subject of suspension. I was looking at those koni yellows and steeda sport springs. I like the idea of adjustable struts/shocks and would prefer them.
Will I need anything else as far as steeda hd upper strut mounts or a panhard bar? polyurethane bushings? Any special tools for the install? (I've got any basic tools and air tools you can think of). I want the back to be symmetrical and I read about rear wheels being outta whack. I would asume I would need an alignment done after all of this?
My car's suspension is stock with 235/55/ZR17 all around on 17x10" rims I believe. Some parts have been replaced but all are ford/motorcraft.
She's "not" going to see a road course but has seen the strip already and I'm planning on getting some upper control arms to help this(right?/suggestions?).
I'm willing to sacrifice more ride comfort than most.
Also this shouldn't put any more wear on the tires or chassis or anything? I can't see how it would but I think that's a legitimate question. Thanks.
Is this a daily driver or weekend car?
SteedaBrandon is offline
Matt's 95 Stang
10-05-2015 07:16 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension noob looking to upgrade
