Third autocross
Third autocross
Did my third autocross today. Did not fare well. Down near the bottom of the pack. Having fun, but it's discouraging when I see the times anyway. Did a novice school a few weeks ago. Unfortunately, didn't get to apply the learning immediately and the improvements I was making that day have dwindled. It will be over a month with work, vacation, etc. before I get another chance. Trying to keep telling myself, just keep having fun and don't worry about results. Just wanted to vent a bit. Got some great advice on the walk through, but when you're on the track less than a minute, there is so much to remember, it's hard to put it all together. I really have to admire the guys that are good at it, and it's amazing to see some of the novices that seem to just have a natural nack for it. Particularly have to hand it to Sam Strano. The Mustang is fun, but clearly not the best weapon for autocross. One interesting thing I've noted though is that I've seen quite a few Mustangs at each event, mostly pre-s197, but a few S197 as well, but NO Camaros!
Keep trying and it will eventually click. Having a good set of tires on a mustang really helps you put the power down effectively. Just keep talking to guys at the races and ask them for their advice on lines to take and braking points on the course.
The Mustang IS suited for autocross once you get rid of some of the largest weaknesses like narrow hard tires, crappy dampers and copious body roll. Even with the weight we have the raw times are not far off smaller lighter vehicles. Some, yes. Will always be faster. You just need to play to the advantages of the car. We can get a lot of tire under our fenders, have great power and torque and can put it down very well coming out of a corner and that doesn't even mention anything resembling a straight line where we just eat other cars.
Locally, an F stock Shelby GT with national level driver is running half a second behind my buddies EvoIX SE in SM trim with a great driver, possibly national level driver. The SGT has less power, more weight, RWD through a live axle of all things (if you believe an IRS to be supperior) narrow wheels and soft spring rates. The ESP boys are about a half a second faster than his EVO on open courses and about the same on tighter courses. They can do it, I promise you! Hang in there!
Will do. Thanks guys. I had the sudden realization last night that I forgot to shut off the traction control. Doh! I found I was a lot quicker without it during the novice school.
I'm running 255-45-18 Nitto 555 all around with Koni STR.T shocks and Steeda sport springs and Steeda HD mounts and an adjustable panhard bar. Those changes made a bid difference from my first time with stock 235 all season tires and stock shocks/springs!
I understand your frustration, but ultimately, as long as you're having fun then I'd keep on autocrossing. If you're not having fun, maybe try something new?
Comparing myself to other drivers, I seem to be "faster" on the roadrace course than I am at autocross. But I enjoy both. I autocrossed my '06 GT yesterday and finished mid-pack, but I was on street tires so I was happy with the outcome.
Experience! I'm glad I seem to be going to "better" direction by starting in autocross and working towards roadcourse work.
As a fellow AX novice w/4 events under my belt, keep plugging away and having fun! Being forced into ESP w/the Shaker I'm basically racing myself due to my still stock suspension, but I relish the challenge of reaching the time goals I've set for myself. Also, i just realized I've been neglecting to disable the traction control - thanks!
I went from autocross to road course driving several years ago and just did an autocross event with my son and his Mazdaspeed 3. I completely could'nt handle it. My rythm and reflexes were so slow. It seemed so much more intense as if I needed some Redbulls to get into it. Road course driving has taught me to be smooth and drive with my head and eyes up, thinking of the next couple turns. It is very different than autocross. If it was easy then anyone could do it and whats the challenge in that?
I feel lucky to participate in driving events with my son and when we drive the road course he is still in a slower group (props to pops) but he has the advantage of youth and will be moving up to my group soon.
Have fun, thats what its all about!
Take advantage of any instructed runs that may be available - hunt down an instructor if that's what it takes. Normally, the instructor sits as a passenger and either coaches you as you go through the course or gives you a review once you're back in grid. The next step might be to let an instructor take a run or two through the course driving your car with you sitting in the passenger seat, where you'll at least get a glimpse of what the car is capable of beyond where you're currently able to get it. The smartest thing I did at a NASCAR driving experience was to take the 3-lap ride-along before my 8-lap drive (and ended up setting the fastest lap speed in the class as a result). There's no reason you wouldn't benefit from the same sort of thing at auto-X.
Autocrosses are generally laid out so tightly that the time it takes you to physically turn the steering wheel from straight ahead to wherever you need to get the car pointed really matters. Particularly with slaloms, you actually need to start turning the wheel slightly before you get to the cone you're about to make a turn at (around?) - and you have to count on tire slip angles and maybe a little sliding to keep you from hitting it instead. Takes some practice.
Norm
squishbang
Suspension
11-02-2015 03:42 PM
