Play between wheels and axle
Old 09-22-2012, 02:00 PM
DG_
DG_'s Avatar
Default Play between wheels and axle
Today, I installed some springs on my '12 GT. After installing the rears, I put my rear wheels back on the studs to tighten them and noticed that there is play between the wheels and axle. I removed the wheel and held the rotor and moved it back and forth and could feel a slight play (maybe 1mm or less) of play.
The movement is very little, but I've never noticed this before and I'm just wondering if that is something I should have looked at.
Does anything have any knowledge on this issue?
Thanks
DG_ is offline
Old 09-22-2012, 03:20 PM
DG_
DG_'s Avatar
Thanks
*Had posted another thread in the suspension sub forum as well, as I wasn't sure in which sub forum it needed to be in.
DG_ is offline
Old 09-22-2012, 04:22 PM
Cobrakev
Cobrakev's Avatar
If you are talking in and out play that is normal. Now up and down play is not normal. That is a sign of axle bearing wear.
Cobrakev is offline
Old 09-22-2012, 04:28 PM
Lem-06
Lem-06's Avatar
pretty sure its gonna move alitle on the studs if your just holding them up to it.
Once you tighten down the lugs it should center everything out and keep them still
Lem-06 is offline
Old 09-22-2012, 07:17 PM
DG_
DG_'s Avatar
Thanks for the replies.
There is only slight play when I push and pull it, even with the wheel on and tightened.
DG_ is offline
Old 09-22-2012, 07:23 PM
Whiskey11
Whiskey11's Avatar
Are you sure the play is between the axle and the wheel? It could be the play from having a c-clip live axle. There will always be a little play. If you take the wheel off and pull and push on the studs, is that where the movement is or are the wheels just not on tight enough?
Whiskey11 is offline
Old 09-26-2012, 08:19 PM
DG_
DG_'s Avatar
Sorry for the late reply.
I haven't had a chance to remove the wheel again. While the wheel was off previously, I noticed the play when I pushed/pulled on the rotor and then again with the wheel on when I pushed/pulled the wheel. Again, the play is very little. I just had never noticed it before which concerned me.
DG_ is offline
Old 09-27-2012, 12:20 AM
JAJ
JAJ's Avatar
The factory spec is 0.030" end play on the rear axles. I had the same clicking noise on one side as you, and mine measured at 0.015". The other side didn't move.
JAJ is offline
Tivo304
08-28-2023 12:19 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Play between wheels and axle
