Brake Pulsation 08 GT
Old 11-17-2012, 12:20 PM
rocky321
rocky321's Avatar
Default Brake Pulsation 08 GT
Changed pads and turned rotors not to long ago. Everything was fine for a few thousand miles. Now I have an intermittent pulsation when braking. I rechecked everything, and did find the outer pad on the passenger side lost its lower tension spring. Could that be it?
rocky321 is offline
Old 11-17-2012, 12:36 PM
157dB
Cut & Paste Expert
157dB's Avatar
Question...
Whom turned these rotors?
Why when new ones are so cheap?
Were they checked for lateral run-out after turning?
What was the reading?
What was the final thickness after turning?
Were the lug nuts properly retorqued to the
proper specs in the proper order or just run
up tight one by one with an impact gun of
unknown quality?
This can also cause pulsating brakes even with
new OEM rotors.
Missing clips will not cause pulsating.
Warped or mis-turned rotors will...
Turning rotors is a fine art and not everyone can do it properly.
157dB is offline
Old 11-17-2012, 12:52 PM
rocky321
rocky321's Avatar
Originally Posted by 157dB
Question...
unknown quality?
new OEM rotors.
Did I mention everything was fine for a few thousand miles??
rocky321 is offline
Old 11-17-2012, 02:53 PM
Andy13186
Andy13186's Avatar
Your responses in both of your threads make you sound like a total ***...
Andy13186 is offline
Old 11-17-2012, 04:55 PM
J95SNAKE
J95SNAKE's Avatar
Agreed.
I think 157dB's questions are on point. My money is on warped rotors.
J95SNAKE is offline
Old 11-18-2012, 09:11 AM
Argonaut
Argonaut's Avatar
While a warped rotor is one possible cause of brake judder there are others. Uneven pad deposits on the rotor for example. This is very common when brakes are used hard and heated beyond their rated capacity. Pad material builds up on the surface of the rotor and when they get too hot it sort of smears and can build up differing depths on the rotor face sending a pulsating feel thru the brake pedal. Looking at your rotors you might be able to see this if its occuring - it looks like round spots on the rotor here and there. If the rotor is totall shiny then this is probably not the issue.
There are several options to deal with this:
- Guys who track their cars usually have track specific pads that are more abrasive when not up to temp. Throwing those on the car and doing some normal street driving will scrape off the old pad material. But, if you don't have a set than this is of no use.
- Pull the rotors off and sand them to remove pad build up.
- Try doing a bedding process - do a few hard brakes from 40, then 60 then 80 mph. Get up to speed and firmly brake until about 10 mph, repeat. Let sit to cool when done. This can sometimes scrape off the high spots.
- New or turned rotors.
Argonaut is offline
Old 11-20-2012, 06:47 PM
05WIMustang
05WIMustang's Avatar
Lets say you have some pads and rotors that are newer (couple thousand miles), can you safely just resurface the rotors, with new pads ?
05WIMustang is offline
Old 11-21-2012, 10:33 AM
157dB
Cut & Paste Expert
157dB's Avatar
Sugar gets better responses than sour grapes on Forums...
You dont answer my questions, you no getty any answers from me...
Go fork yourself and fix your own problems...
Leave us alone...
157dB is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake Pulsation 08 GT
