Pinion angle question
I plan on getting coil-overs and i plan on lowering it about 1.5 inches (i have long tubes and I dont want to destroy them) I was wondering if anyone had pinion angle issues with that height drop (1.5 inches) I want to make sure I have everything for my coilover install ready. I got a good deal from jay at hyper motive on coilovers
You don't need anything adjustable, not even a PHB. Where need means you have to have it or you will have an issue that is.
You can put the c/o's on without an Adjustable UCA, Adjustable LCA's, LCA brackets, or even an adjustable PHB. There are reasons for each, but none of those are 100% must do things.
I disagree... The car will shift some, but it's not a mile. See also every Shelby GT made that was lowered and did NOT have any adjustable parts under it, including a PHB. Also some cars sit off the wrong way at stock height, particularly Brembo cars, and lowering squares them up. But even in normal cases we are talking 1/8 to 1/4" off laterally most of the time, and again you had OEM cars that were this way.
Don't get me wrong, it's not a bad idea and even better is a Watts link as they handle WAY better. But there is a difference between *have to have* and something to think about.
And keep in mind, I also sell PHB's.... I have no ulterior motive to say this other than it's true. Not like I risk losing out because I don't have the parts, I have lots of PHB options.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
