2013 GT no straight line stability
Old 03-13-2013, 10:29 AM
Norm Peterson
Norm Peterson's Avatar
Karter - I agree with bgoose in that toe is probably involved. Although static toe is the easiest thing to check and correct, in the current crop of cars there are other things to check.
Make sure they give the EPAS a very close inspection, as some of the compensations that can be built into it can affect the car's directional stability. Think "drift-pull" or possibly "active nibble control".
On edit, perhaps they should also look at the AdvanceTrack and its steering wheel position sensor.
Norm
Norm Peterson is offline
Old 03-13-2013, 10:25 PM
908ssp
908ssp's Avatar
Sounds like toe out to me. I run 275-35/20 on the front and don't have any wondering feeling. Never had before and during all the suspension changes I have made. Just keep the toe 0 to -1/8" and it should wonder.
908ssp is offline
Old 03-16-2013, 12:12 PM
157dB
Cut & Paste Expert
157dB's Avatar
Caster is for steering return to center.
Toe is the wandering problem.
Slightly in and it will track straight.
Lowered stangs will exhibit toe neutral or
out if you dont get it reset to slightly in
after lowering springs are installed...
Toe can be set with two boards and a two tape measure rs...
ps static toe and rolling toe are two different things....
157dB is offline
TCStangerv6
10-11-2015 05:57 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
fastbackford351
10-01-2015 12:24 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: 2013 GT no straight line stability
