New Suspension - Any thoughts?
Old 03-27-2013, 06:12 PM
pinn
pinn's Avatar
Default New Suspension - Any thoughts?
1 Eibach Pro-System-Pl us (05-10 GT)
1 Eibach Pro-Alignment Camber Adjustment Bolts
1 Ford Racing GT500 Style Strut Mount Upgrade
1 J&M Adjustable Panhard Rod Steel
1 Eibach Pro-Alignment Rear Lower Control Arm
After reading previous threads, here is the list I put together. Anyone have any thoughts on this package? or recommend anything different?
The setup is going on an 06 GT to replace stock parts.
pinn is offline
Old 03-27-2013, 06:33 PM
UrS4
UrS4's Avatar
Forget the camber bolts and GT500 mounts and get Steeda HD mounts which correct for camber or MM plates
UrS4 is offline
Old 03-27-2013, 06:54 PM
CMcNam
CMcNam's Avatar
Agreed. I'll throw in the J&M plates too. Reading through the stuff here, I don't think I'd ever touch camber bolts.
CMcNam is offline
Old 03-27-2013, 07:00 PM
pinn
pinn's Avatar
1 J&M Camber Plates (05-10 All)
Based on the feedback so far, how does this list look instead?
pinn is offline
Old 03-27-2013, 08:32 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
That's a good setup, although I'd recommend UPR LCAs and PHB.
UPRSharad is offline
Old 04-15-2013, 08:39 AM
Code Vision
Code Vision's Avatar
Hey guys...any reason you don't favor the bolts? I understand they are not adjustable and have read that they are only JUST able to correct for the camber, but for a daily driver you don't think this is sufficient?
Is there maybe a reliability issue?
Code Vision is offline
Old 04-15-2013, 08:42 AM
CMcNam
CMcNam's Avatar
Heard a few stories of them becoming...unadjusted...while driving. Don't use a band-aid to fix something that requires stitches.
CMcNam is offline
Old 04-15-2013, 09:19 AM
Andy13186
Andy13186's Avatar
i have bolts and i dont seem to have any issues, i havent done track days or anything with them though.
Andy13186 is offline
Old 04-16-2013, 07:24 AM
Code Vision
Hey pinn, is this for track? Daily driver? Did you order/install this setup?
I'm curious because mine is a DD and I'm wondering what kind of difference LCAs would make. I got what you got for my 13, except the LCAs. The AM guys talked me into the plates instead of the bolts. But that I put the last of my budget toward them, so I can't swing the control arms right now.
Old 04-16-2013, 07:43 AM
Ablaze
Ablaze's Avatar
I'm not trying to play devil's advocate but in the dozens and dozens of threads I've read about bolts vs plates I've seen more complaints about plates (noise, clunking) and more 'stories' about bolts than anything else. I've contacted some of the big speed shops and tuners both locally and across the country with questions ranging from blocks to suspensions and whenever I asked about the safety of bolts versus plates they never hesitated to give a thumbs up even if they weren't the ones selling them. I'm sure I could find someone that has had problems with them but it isn't as people have made it out to be. Just makes you wonder if it's an internet conspiracy, no offense to anyone.
Ablaze is offline
Quick Reply: New Suspension - Any thoughts?
