relocation brackets, adj lca's and squaring rear axle
Another thread with this issue, damn... I saw that post on SVTP so I ran outside to check and sure enough with my BMR LCA's and relo. brackets, my rear was .5 in up in the driverside than the passenger and my steering was off center when cruising. I went downstairs earlier to take the brackets off, and BAM. Gap is even on both sided and my steering wheel is centered.
Can these brackets really be that messed up? I would hate to have to sell my LCA's to buy adjustables just to use the brackets.
Either way, the gap is quite noticeable.
An off-center steering wheel when driving down a straight level road is perhaps the easiest thing to notice. On adjustable-length LCAs, it only takes 1/8" LCA length difference to clearly show up at the steering wheel.
Given that adjustable LCAs all use firmer bushings or pivots than the OE LCAs, you might not want to set exactly the same pinion angle. Maybe just a little shorter than the OE LCAs for a little less PA is what you really want.
Norm
There isn't any room for error during installation, they only go on one way and it's a tight fit. Also everyones axle is off the same amount and on the same side. It's also not limited to to one manufacturers brackets. Norm, have you installed anti-squat brackets?
I think a lot of peoples axle are crooked after installing these and they just don't notice. I'm not sure how your rear axle can cause your steering wheel to be off center while cruising. My steering wheel was off center when I changed my tie rod ends, but the alignment shop fixed that. The only time I really noticed the axle being off was during WOT, it would pull or rather push me towards the right. I thought my diff was just on it's way out.
If this is a consistent thing across several bracket mfrs, it would make me wonder if Ford had introduced a minor running production change that most of the aftermarket did not pick up on.
When thrust angle is off, the car is dog-tracking and you have to steer the steering wheel out of its "straight ahead" position so that the front tires are back to being parallel to the rear tires. The whole car is running down the road at the same angle to the road as it is to the not-square rear axle. All four tires are running parallel to each other and obviously parallel to the road, but not parallel to the body. The two rear tire tracks are slightly offset relative to the two front tire tracks. If you're having to steer to the right to go straight, the rear tires are tracking to the right of the front tires.
I noticed this right away when I put the Currie LCAs in my car and didn't get them matched correctly. This was clearly noticeable at steady speed driving straight ahead (where I had to steer the wheel by 10° or so to the right) or following a very gradual left curve (where the steering wheel was then perfectly centered). I was off by 1/8", and one full turn shorter on the right side LCA adjustment on dialed out every bit of the error and I got my proper steering wheel orientation back. My LCAs are not on-car adjustable, meaning I had to disconnect one end to do this. The good thing is that the LCA settings cannot creep even if the jam nuts come loose.
If you think about it a bit, knowing which way the steering wheel is off tells you which LCA to adjust shorter (or which one longer if you prefer).
All of the above is why I won't ever suggest installing relo brackets without strongly urging adjustable LCAs.
Norm
I think my problem is I don't drive on any flat, smooth enough roads to notice the car was dog tracking, now if it was this bad, I think i'd have paid more attention.
My CHE brackets did not have any wiggle room at all, the bolt holes just barely lined up enough to get them through.
Grabber blue, you sure escalated that post on svtperformance. Someone mentioned hitting the brackets with a big hammer. I don't think I would attempt that. Your more likely to damage the stock brackets.
11-10-2015 11:39 AM
09-16-2015 07:53 PM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
