suspension mods that will help me get traction
Old 08-03-2013, 04:22 PM
DTMR
DTMR's Avatar
Default suspension mods that will help me get traction
Went to the track and kept sliding through first and second gear. Besides obviously needing slicks is there any other mods I should get suspension wise? how should I set the rebound and compression on my coilovers?
DTMR is offline
Old 08-03-2013, 06:13 PM
427Roush
427Roush's Avatar
LCAs and a UCA. You've got to play around with your adjustment clicks on the KW coil-overs. Just my .02 cents.
427Roush is offline
Old 08-03-2013, 09:03 PM
CMcNam
CMcNam's Avatar
Definitely lower control arms. It is recommended to have at least one end be some sort of spherical joint to prevent binding. I upgraded mine and it made a world of difference in my traction. It's a really easy upgrade to install at home and definitely worth any price.
CMcNam is offline
Old 08-04-2013, 06:52 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Yup. UPR control arms. You can keep your shocks fairly stiff, but loosen up the REBOUND side of the struts. That's what I do with my Konis and my '06 hooks hard.
UPRSharad is offline
Old 08-05-2013, 11:05 AM
DTMR
DTMR's Avatar
the rebound of the fronts and backs?
DTMR is offline
Old 08-05-2013, 06:28 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Just the front. You want the rear end to stay down, and the stiff rebound on the rear shocks will keep it down. But loosening up the front rebound will let the front end rise.
Old 08-06-2013, 08:26 AM
tj@steeda's Avatar
Are you looking to keep tracking it or do you have other plans down the road? Also, your budget will determine the type of set-up you can go with.
If you would like, you can email me at tim @ steeda.com and we can start looking at the different packages we can put together based on your goals/budget.
Best Regards,
TJ
tj@steeda is offline
Old 08-15-2013, 01:05 AM
lawman1
lawman1's Avatar
Torque Arm.
lawman1 is offline
Old 08-16-2013, 10:31 PM
silverstang23
silverstang23's Avatar
I would work on adjusting the bump (bottom) on your v3's. Our mod's are similar with the exception of cams and I have no traction issues. I have 305 super sports and I cannot spin them with my "track" setting on the c/o's
silverstang23 is offline
Old 08-16-2013, 10:58 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
has anyone tied in LCB's with a Swarr-Bar?
Hay Lady, up there! See me I'm a cute Monkey, scratch my head.
VistaBlueFrank68 is offline
Quick Reply: suspension mods that will help me get traction
