285/40/18 square set up
Recently put on 18x10 drift wheels with 43mm offset on all four with Nitto NT555 285/40/18
Lowered on Ultralites
No rubbing at full lock, 8 mm clearance on struts
-1.3 degrees neg camber
Wanted to post this since it has always been a huge debate if that wide of a tire and 10 inch wide wheels can fit without issues
I really don't think that 18x10 +30 will work with 285/40 front tires unless you're willing to leave more wheel gap than most folks seem to want to.
+30 gives more clearance to the strut but puts you half an inch or so further out toward sheetmetal to outer shoulder rubbing. 8mm of strut clearance is plenty.
Norm
Norm
In +30? Really?
Even if it clears with the car just sitting there, I can't picture there being enough clearance to be able to drive it very hard.
285/35's on 18x10 +43-ish will fit without rubbing even with more lowering than there is difference in height between 285/40 and 285/35. 285/40's on these wheels clearing at OE ride height is expected.
Norm
Norm
