Coilovers & Camber Plates.
Old 01-10-2014, 12:54 PM
2007CalSpec
2007CalSpec's Avatar
Default Coilovers & Camber Plates.
I'm looking for some coilovers and noticed that some manufacturers use camber plates like the one in the picture. If I'm not mistaken, it would be a pain to adjust the camber since you'd have to drop the strut away from the strut tower to loosen the four allen bolts. Am I correct?
2007CalSpec is offline
Old 01-10-2014, 01:04 PM
ModBargains
Former Sponsor
ModBargains's Avatar
Good question!
European style coilovers do NOT come with camber plates (ie: KW Coilovers, Bilstein Coilovers, and so forth). JDM style coilovers usually DO come with camber plates (BC Racing, HKS and so forth).
The adjustment for the camber plate is easy. If the kit was designed properly, you will not have to adjust the camber while the coilover is taken off the car, you can do it while it's on the car, but I would jack up the side that you're adjusting first, then loosen the 4 allen bolts, and then make your adjustment, then tighten down. Once you do it a lot you get used to it.
Hope that helps! Let me know if I can help out with anything
ModBargains is offline
Old 01-10-2014, 01:09 PM
Flat out
Flat out's Avatar
http://www.ground-control-store.com/...gory.php/CA=96
Flat out is offline
Old 01-10-2014, 01:11 PM
ModBargains
Former Sponsor
Or you can get set up with what we've got which is Vorshlag, who actually practices what they preach in their product by having a Mustang that they competitively race with their camber plates of course:
AND they currently hold the records under NASA TT3 with this car for 2013:
Motorsports Ranch Houston (2.38 CW), 1:41.544, Jan 19, 2013
Motorsports Ranch Cresson (3.1 CCW), 2:22.753, March 17, 2013
Texas World Speedway (2.9 CW), 1:51.530, April 21, 2013
New Orleans Motorsports Park (2.75 CW North Course), 1:50.535, May 5, 2013
Hallet Motor Racing Circuit (CCW), 1:24.365, June 23, 2013
Hallet Motor Racing Circuit (CW), 1:26.786, June 23, 2013
Texas World Speedway (2.9 CCW), 1:50.675, Sept 22, 2013
Eagles Canyon Raceway (2.5 CCW), 1:52.250 Nov 2, 2013
Pretty badass!
Old 01-10-2014, 01:31 PM
Flat out
Flat out's Avatar
Well, I guess that settles that.
Flat out is offline
Old 01-10-2014, 01:33 PM
ModBargains
Former Sponsor
Ground Control is good, don't get me wrong, but Vorshlag has done so much testing on these camber plates for the S197 that it just makes it a bit unfair to the rest of the market, haha.
Old 01-10-2014, 02:29 PM
Flat out
Flat out's Avatar
I think you're right, they're both very good, but camber plates who ever made them don't win races, I think we both know that there is a WHOLE LOT more that goes into preparing a winning race car. I know because this car has won some races.
Flat out is offline
Old 01-10-2014, 03:32 PM
ModBargains
Former Sponsor
Of course, you're 100% right. My 10 years of racing will contest to that fact, but it's still kind of bad *** to know that the camber plates were abused on the track with this Vorshlag car, and they held up really well. The suspension set up on that car alone is over $6,000+ so I know it's not just the camber plates
Old 01-10-2014, 08:02 PM
2007CalSpec
Good question!
Most of the JDM style coilovers are the ones with the camber plate I posted earlier. I think I won't be able to access the 4 camber adjustment bolts while the strut is bolted into the strut tower. The opening of the strut tower isn't large enough to allow access.
Just to show the strut tower opening.
Ground Control is what I've been considering. I've looked at just about every coilover kit out there. Ground Control has everything I want in a coilover. It's in my price range, has the easier-to-adjust camber plates (in car adjustment), adjustable dampening, and your choice of custom spring rates. Only thing is their customer service sucks.
Old 01-10-2014, 09:32 PM
Flat out
Flat out's Avatar
You might think I'm crazy, but I would give them a call and tell them just that in the nicest way you can, if you do one of two things will happen, you'll get an attitude from them, or, you might get good customer service, I do think the product is the best bang for the buck. You can spend a lot more for less in my opinion.
Flat out is offline
Quick Reply: Coilovers & Camber Plates.
