Lighter aftermarket muffler's effect on rear suspension
Old 01-27-2014, 03:58 PM
magnido45
magnido45's Avatar
Default Lighter aftermarket muffler's effect on rear suspension
Will the lighter aftermarket performance over axle systems like Roush and Kooks that are close to 20lbs lighter than the stock mufflers, make any
difference in the way the rear end's suspension feels/performs? Like going over speed bumps, etc...
magnido45 is offline
Old 01-27-2014, 04:00 PM
WJBertrand
WJBertrand's Avatar
No more difference than placing or removing a duffle bag in the trunk I suspect.
WJBertrand is offline
Old 01-27-2014, 04:23 PM
magnido45
magnido45's Avatar
hmm...now that I think about it...I could remove the spare tire and test it out...
Old 01-27-2014, 09:39 PM
artdohc
artdohc's Avatar
No it won't.
If you are that worried about it, move your battery to the trunk. It'll add weight to the rear and remove weight from the front, giving you better weight distribution.
artdohc is offline
Old 01-28-2014, 05:02 AM
audioAl
audioAl's Avatar
I have a full spare in my trunk, barely fit in the well, but well worth it, well,well. Dang!
audioAl is offline
Old 01-28-2014, 06:41 AM
BrazenStang
BrazenStang's Avatar
Short answer: No.
Long Answer: If you are concerned about shaving weight in every possible location, then a -20 lb. change will definitely help with your weight shaving goal. Based on the total weight of a vehicle you would need to shave a substantial amount of weight to notice a difference in handling. Bags and gear in the trunk can easily weigh more than 20 lbs. so I don't think you have anything to worry about.
BrazenStang is offline
Old 01-28-2014, 09:00 AM
Norm Peterson
Norm Peterson's Avatar
Theoretically there would be some small difference(s), just that they'd be too small for most peoples' butt-dynos to distinguish.
If you're one of those rare people who really could reliably distinguish vehicle dynamic differences between the two exhaust systems without knowing which was on the car you should probably consider applying for a position as a factory or race team test driver.
Norm
Norm Peterson is offline
Old 01-29-2014, 09:22 AM
magnido45
magnido45's Avatar
Norm
I currently don't have the driving skills, but I do have the butt-dyno...what a cool job that would be
FivePointToTheOh
10-02-2015 04:09 PM
musnicki
09-23-2015 07:11 AM
GimpyHSHS
09-18-2015 12:27 PM
09-08-2015 11:50 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: Lighter aftermarket muffler's effect on rear suspension
