Chamber Bolts?
Old 02-23-2014, 02:03 PM
JAJ
JAJ's Avatar
Further research reveals that H&R is not selling camber bolts any more. OEM Ford part is 4R3Z-3B236-AB for the "crash bolts"
JAJ is offline
Old 02-24-2014, 08:53 AM
todcp
todcp's Avatar
Is the Ford part strong enough for track use and full torque spec? Is it better to just file out the top strut spindle hole? Or neither. Sure wish I could get a bit more negative that the Steeda Springs and Koni allow due to rubbing.
This is what I found when using this part number. Correct?
CAM
Make: Ford | Part#: 4R3Z3B236AB
List Price: $168.60
Your Price: $113.30
todcp is offline
Old 02-25-2014, 12:42 AM
JThor
JThor's Avatar
Is is truly OEM strength? Also, does the bolt and mod make the camber adjustable or do you get a single, altered camber spec?
JThor is offline
Old 02-25-2014, 05:39 AM
Norm Peterson
Norm Peterson's Avatar
Seems to me as soon as the appropriate bolt holes are opened up you have the ability to set anything within the range that the additional hole clearances permit.
So I looked it up anyway . . . keep in mind that this was taken out of a 2008 Service Manual when the older coarse thread bolts were still in use, so you might want to make sure that fine thread camber bolts exist. Worst case, 148 ft-lbs is still better than 80 or less.
Originally Posted by Ford Service
9. Using alignment equipment and the manufacturer’s instructions, measure the front camber.
10. Using the cam bolt, adjust the front camber until it is within specifications.
• Tighten the strut-to-wheel spindle cam nut to 200 Nm (148 lb-ft).
• Tighten the strut-to-wheel spindle upper bolt to 200 Nm (148 lb-ft).
11. Recheck the front camber settings, adjust as necessary.
Norm
Norm Peterson is offline
Old 02-25-2014, 06:14 AM
Norm Peterson
CAM
List Price: $168.60
Your Price: $113.30
If that's what they cost, it gets a whole lot easier to just move up to camber plates.
Norm
Last edited by Norm Peterson; 02-25-2014 at 06:17 AM. Reason: delete extra blank lines that forum software inserts
Old 02-25-2014, 03:12 PM
todcp
todcp's Avatar
Here is a scan of the Ford factory "Cam" bolt. My service manager says it is a strong as the regular stock bolt. Appears to use a "cam" on the bolt head vs the bolt itself. Not sure how it works yet. Retail is indeed 168 dollars so Ford thinks it is a pretty special bolt!! It can be bought for 113.30 as stated in my post.
Need to check if the price is each or for a pair. It may be each....ouch.
todcp is offline
Old 02-25-2014, 10:07 PM
todcp
todcp's Avatar
Norm
I have Steeda HD camber plates. Max neg camber with struts is in the -2.1-2.3 range and I would have liked to hit closer to -2.8 when at the track. Guess I will just relax about it and take the camber I can get. Not racing, just track fun.
todcp is offline
Old 02-26-2014, 01:36 AM
JThor
JThor's Avatar
Norm
I would much rather do camber plates, but it will push me out of F-Street. Neg. -2.0 Deg., is enough for street tires. Even -1.5 Deg. would probably be ok.
JThor is offline
Old 02-26-2014, 11:27 AM
J95SNAKE
J95SNAKE's Avatar
I used bolts (Eibach) one year and the threads stripped out from the repeated adjustments. They never failed except for that. This year I just plan on using a tire I can flip on the wheel so I can participate in FS all year.
J95SNAKE is offline
Old 02-26-2014, 02:04 PM
Derf00
Gentleman's Relish
Derf00's Avatar
That picture looks to be correct. if you look at the struts (at least the OEM and OEM replacement type struts like KYB), they have a raised notch where I could see that CAM pushing up against it as you rotate it to give you the additional camber.
And one thing I've learned is that you can buy from several different Ford parts houses and get a better price. .
Ford Parts Giant for example lists these for $119 each....EACH!? Normally they are less than 1/3 of the dealers for all the other nuts and bolts and body plugs I've purchased from them. I wonder why they are so expensive...but don't need them so don't really care.
Derf00 is offline
Quick Reply: Chamber Bolts?
