Defeated: upper control arm interior bolt stuck
resolved: upper control arm interior bolt stuck, see inside
Evening,
I have a '14 V6 Mustang I'm slowly building up. I'm tackling the control arms & I can't for the life of me break the upper control arm bolt free - the one inside the car under the rear seat. I've applied a breaker bar AND a air impact wrench. What kills me is I've seen pictures of people going at it with a standard ratchet wrench. I'm replacing the control arm & the bracket so any input on breaking it free would be appreciated. The socket it takes is a 24mm which is much bigger than I've seen listed used by others... did they change the bolt for '14?
2011 and later used a larger bolt that takes a LOT more torque than the 2010 and earlier cars.
That bolt could be torqued down to as much as 240 ft-lbs, as that's what BMR specifies in their 2011-up bracket instructions (step 13).
The earlier cars only needed 129 ft-lbs, which is do-able by a reasonably strong person with standard square drive wrenches.
http://bmrsuspension.com/siteart/install/UCM002.pdf
Norm
Norm
24" breaker bar and if necessary a 3' piece of 3/4" or 1" pipe (whatever size required to slip into the breaker bar handle) and have Wheaties for breakfast. Good luck!
I have an 08 and there was Loctite on the factory bolt. I can't remember if it was high or medium strength, but based on the effort it took to do it could have been high strength red.
Matthew
Evening,
I went with a larger air impact wrench & some taps on my breaker bar with a 3lb sledge. still won't budge. Glad to hear it's tough bolt to crack on the '11+. I'm going to take it to a shop just to let them put a heavy duty impact on it. The rest I can get myself from the bottom. And the new bolt is the smaller one from prior years so it only needs to be torqued to 129 ft-lbs.
Using a small-bolt bracket to replace a big-bolt bracket makes me a little uneasy . . . Ford significantly upgraded that bolt for a reason.
If it was me, I'd arrange to get the correct bracket.
But at the very least you should plan on inspecting that particular bolt for pulling through the body sheetmetal, and if the bolt is long enough you should use a heavy close fitting washer under the bolt head to spread the bolt load out better so it won't be as likely to do that.
Norm
Norm
