Ford Racing lowering Springs question
just in case you still need info, i did the K springs (1.5" drop) with eibach shocks/dampers. the ride quality is damn near stock, and it wasnt that badly priced. I also did panhard bar, but nothing else. Car runs just fine, eveyrthing is lined up, no issues whatsoever. I did get an alignment after all the install, no caster cambper places or strut mounts needed on mine.
Glad to hear. I install mine a couple of weeks ago. Didnt change the struts or the mounts. Drives nice. It's not bouncy like some people say. No popping sound either. Haven't installed the rears as I don't have the panhard bar. Doesn't look bad either since the back is higher than the front. Haven't taken it yet for an alignment. Need tires so when I get those ill have that checked out. Thanks for the feed back
Bought my car at beginning of April. The previous owner put the P-springs on it with nothing else. Since I have put a BMR adj. bar on the back to get it centered up and got an alignment to get the front as close to 0 degrees camber as possible. I do hear a popping noise in the front and yes I am using the stock GT mounts. I don't understand why ford puts our cars out with all the negative camber in them. Only 7600 miles on mine and I had noticeable tire wear.
After I installed them I noticed my passenger side popping. I was like ah crap, I'm a victim. But I went and tighten the center mount bolt tighter and popping noise went away. That bolt is a pain to tighten since the center spins on you. Try tighten the bolt and that popping sound may go away. Let me know how it goes.
But yeah as above stated. Taken short cuts and cost you a lot more at the end. I may have just gotten lucky.
squishbang
Suspension
11-02-2015 03:42 PM
