Mustang sitting uneven?
I just installed my Koni oranges or STRT's, eibach pro kit springs, and j&m panhard the other day and it is such a noticeable difference. I can feel the road more in my GT, almost as if im planted to the ground. I love it.
Im having one issue though. i noticed a noise coming from the passenger side in the rear so i started checking things out. My bump stop back there seems to have a lot less room than the one on the drivers side. I can fit like 1 finger between the bumperstop and the car on the passenger side, while the drivers side can fit like 3. This is leading me to believe the body is sitting awkwardly for some reason.
Anyone know what exactly is going on or have any thoughts? I centered my axle yesterday (wednesday, installed everything on monday) and i thought that was part of the problem but apparently not.
The eibach name and numbers on the springs are facing outard away from the vehicle on both sides.
I just had a thought... is it possible I over-tightened the upper shock nut on that side and this could be causing the problem?
ALSO... i just realized again... I think I tightened everything back up while the jack was holding up the rear diff. I am 100% sure that the axle was NOT sitting on jackstands and properly loading the suspension while I tightened everything back there. I DID have them under the panhard i believe (which is now centering the axle). Could this be the problem??
Steeda's rear spring installation instructions mentions re-using upper and lower rubber spring seats. Are you missing any?
The front corner diagonally opposite to a low rear corner may be too high, or diagonally opposite to a low rear corner too high, so part of the problem could be at the other end of the car.
Norm
Norm
Norm
Norm
Norm
Im not sure whats going on with it anymore lol. I originally knew something wasn't right because while I was test driving it, I heard a noise coming from that same corner where the car was sitting lower. Now I noticed the noise is gone and im pretty sure the whole car is sitting evenly too. Possible that everything still needed to settle?
