Adjustable UCA Pre-Adjust
Anybody have a pre-adjusted length they set an adjustable UCA before installation so it's ballpark? I have a UPR adjustable UCA w/bracket and I'll be lowered with Eibach Sportlines.
That's exactly what I did with mine. Laid the UPR arm and mount next to the stock arm and mount and matched the lengths up. It still required a little adjustment in the car though. Presumably from the lowering springs.
Hmmmm . . . I'd have expected longer, only partly because the firmer bushing in the adjustable UCA should require less PA than the OE rubber thing does.
I don't see this ever needing too much adjustment from the OE length. A 1/8" UCA length adjustment looks like about 0.6° PA change.
Norm
Norm
Yeah, I agree with you and Norm. Based on the 3-link suspension geometry and lowering the car, the UCA should be slightly longer to adjust PA back into spec.
