Eiback springs on OEM shocks or BC coilovers?
Old 08-11-2014, 07:59 PM
BenV8
BenV8's Avatar
Default Eiback springs on OEM shocks or BC coilovers?
hi guys, I begin to shop better suspension for my mustang. severals on this forum has installed springs on oem shocks and others coilovers. But by experience on a other car I had installed Eibach pro kit springs on oem shock and after 10 000miles the shocks began to have leaks.
I'm confused, what do you suggest me between coils Eibach pro kit or Bc coilovers?
many thanks
BenV8 is offline
Old 08-12-2014, 06:57 AM
BenV8
BenV8's Avatar
No answers?
BenV8 is offline
Old 08-12-2014, 11:44 AM
BenV8
BenV8's Avatar
Thanks for your help
BenV8 is offline
Old 08-13-2014, 01:08 PM
rcazwillis
rcazwillis's Avatar
I imagine you will get some responses this evening. Your post times are not typically active times for this forum. I find they are evening posters. Patience will get you an answer.
I have Eibach springs that I have not installed yet. I am also curious if the OEM shocks work with the springs. A stiffer spring usually needs a stiffer rebound on the shock to control it properly.
rcazwillis is offline
Old 08-14-2014, 09:03 AM
BenV8
BenV8's Avatar
I apologize I don't know how is work here because I'm new. Usually in other forum when you ask a question people give a answer in the same day.
I'm agree with you, I'm not sure if lowering springs with stocks struts give a good result. I think I try coilovers.... did you hear something negative about BC coilovers?
BenV8 is offline
Old 08-14-2014, 09:10 AM
jRaskell
jRaskell's Avatar
Generally, they don't give good results, but that really depends on exactly what results you are looking for.
If you just want the looks, and aren't so concerned with the handling, then it may be an acceptable path. If handling is a priority for you, then a good set of shocks/struts should be your starting point, and build from there.
There are plenty of options between lowering springs/stock shocks/struts and coilovers, so not really sure why you're focused on those two extremes.
jRaskell is offline
Old 08-14-2014, 07:36 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
I'd recommend these springs:
http://www.uprproducts.com/mustang-e...prings-05.html
With these shocks and struts:
http://www.uprproducts.com/strange-m...-strut-11.html
http://www.uprproducts.com/strange-m...-shock-05.html
And this adjustable panhard bar:
http://www.uprproducts.com/mustang-p...rd-bar-05.html
UPRSharad is offline
Old 08-22-2014, 07:03 AM
BenV8
BenV8's Avatar
thanks for your help all I appreciate!!
BenV8 is offline
Old 08-23-2014, 09:45 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Anytime dude!
Old 08-24-2014, 04:29 AM
howarmat
s197 Junkie
howarmat's Avatar
I ran the FRPP springs on OEM shocks for about a year and it was not bad. But the ride was better once i put the new shocks on.
howarmat is offline
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
winner99
10-01-2015 10:52 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Eiback springs on OEM shocks or BC coilovers?
