I think I've become an addict ......
I have done so much to my car's suspension that now I'm concerned I may have gone too far. I have an 06 Roush Stage 3 so it started with the larger sway bars, but since then I have installed a BC Racing Coil-over system, Fays-2 Watts link, Whiteline rear LCA's, Steeda 3-point frame brace, FRPP lower front control arms and A-arm brace, Steeda "X" brace, ball joints and bumpsteer kit. My question is: does all of this compliment each other or have I just been taking one step forward and two steps back.
That's a good parts list. I'd also recommend this:
http://www.uprproducts.com/mustang-c...-mount-11.html
^^it's stronger than the stock setup, eliminates the slop, gives you the ability to adjust pinion angle, and that particular combo gives you the improved UCA geometry of the 11+ cars.
These brackets will correct your rear suspension geometry after the drop from your BC coilovers:
http://www.uprproducts.com/mustang-l...et-kit-05.html
