Upgrading Shocks/Struts. Camber plate vs bolt
Old 08-12-2016, 11:42 AM
jordanair45
jordanair45's Avatar
Default Upgrading Shocks/Struts. Camber plate vs bolt
A while ago I lowered my car with eibach sportline springs.
I now need a panhard bar and new shocks/struts since the ride is really bouncy now, dangerously bouncy.
Since I am going to be pulling out the old struts, should I also install some caster/camber plates? Or would a camber bolts be enough?
I think my camber is a little negative, maybe 1-1.5 from factory. If I remember correctly, one side was in spec, but the other was not. Wish I saved my alignment sheet.
jordanair45 is offline
Old 08-13-2016, 07:57 AM
Norm Peterson
Norm Peterson's Avatar
Use either the camber plate method or, very specifically, Ford's own camber bolt approach (which requires elongating holes in the struts' "ears").
Better still might be Steeda's HD strut mounts, which feature camber adjustability and have at least in the past been more durable for lowered cars than the OE strut mounts (which sometimes come apart when you remove them anyway). Give Sam Strano at Stranoparts a call because there's more than one part number for these.
Cambers that are a little negative is fine. Ford has typically preferred -0.75°, and allowed all the way up to -1.5°. And although Ford won't ever endorse it, cambers even further negative are still do-able without big downsides if you take corners enough harder than the average sedan driver often enough.
Norm
Norm Peterson is offline
Old 08-13-2016, 01:19 PM
jordanair45
Norm
Thank You.
rocky321
05-05-2016 09:25 AM
rocky321
04-11-2016 12:57 PM
blkbeltolson
03-19-2016 01:19 PM
tsst04
08-07-2003 03:56 PM
mustagnbrei
07-18-2003 07:50 PM
Quick Reply: Upgrading Shocks/Struts. Camber plate vs bolt
