Rear Bump Stop
Old 08-21-2016, 10:52 AM
rocky321
rocky321's Avatar
Default Rear Bump Stop
What would cause one side to chew up like this? 08 GT Vogtland lowering springs and Koni STR shocks
rocky321 is offline
Old 08-21-2016, 05:13 PM
Moderator
JimC's Avatar
The springs lowered the car and the bump stop is slamming into the body.
JimC is offline
Old 08-21-2016, 05:17 PM
g150rdt
g150rdt's Avatar
You need to replace them with new ones and cut 1" off the top.
g150rdt is offline
Old 08-22-2016, 07:43 AM
rocky321
rocky321's Avatar
Just one side?
rocky321 is offline
Old 08-22-2016, 07:52 AM
Norm Peterson
Norm Peterson's Avatar
Is the other side's bump stop damaged at all? If not, either your axle isn't accurately centered or the bump stop was defective to begin with (not too likely, but possible).
Which side of the car are you showing?
How long/how many miles on your Vogtland/STR.t setup? I'm not at all convinced that the STR.t is up to controlling the Vogtland's rear spring rate.
Norm
Norm Peterson is offline
Old 08-22-2016, 09:01 PM
rocky321
rocky321's Avatar
Norm
Its the drivers side. The passenger side bump stop is fully intact. 40,000 miles on that setup. I'm leaning toward the STR.t shocks also. They have this "dead feel" to them over road ripples. I was thinking a set of KYB monotubes. Not understanding an axle off center eating up a bump stop though?
rocky321 is offline
Old 08-22-2016, 09:15 PM
Norm Peterson
The bump stop might not be getting hit squarely at its center point, which means that contact would try to tear it as well as compress it.
Norm
Old 08-23-2016, 10:36 AM
rocky321
rocky321's Avatar
Thumbs up
Norm
Got it! I ran a plumb line from each fender and measured from the rim lip to the line, and its dam near exact. I know you like the Koni yellows. Any other suggestions?
rocky321 is offline
Old 08-23-2016, 11:55 AM
Norm Peterson
Bilsteins are a good choice if adjustability is not too important to you. Some people are adamant that a monotube design is inherently better than a twin-tube design, but adjustability does have its advantages.
Norm
NorthAmericanTuning
10-12-2016 10:10 AM
Violator187
08-17-2016 02:43 PM
1sicsaleen
Suspension
08-16-2016 06:22 PM
frostydudes
3.7L V6 Technical Discussions
08-15-2016 08:45 AM
07-28-2016 09:02 PM
Quick Reply: Rear Bump Stop
