Flywheel/Clutch TSB and damaged transmission question
S197 Shelby SectionThis section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Mine pretty much smooths out after warm..but again I give a slight hesitation when shifting to second...
+1, Same here.
If your concerned, try this...
With the car on level ground, push the clutch in and put the car in first gear.....take your other foot off the brake. Don't let the clutch out and don't take it out of first gear....just sit there. Being level ground the car should not move forward or backward. If you feel the car inching forward, you have a symptom and should go talk to your Ford dealer and let them know that....or just go have an aftermarket clutch thrown in the car, and never ever worry about this happening again.
