S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
NEW: Mcleod Sprung Hub RXT Setup for 2010+ GT500's
Old 02-28-2012, 01:29 PM
Boostaddict
Former Sponsor
Boostaddict's Avatar
Default NEW: Mcleod Sprung Hub RXT Setup for 2010+ GT500's
NEW from Mcleod for the 2010-2012 GT500 is their sprung hub RXT Twin Disc clutch setup. (Uses the stock slave cylinder and flywheel)
Mcleod 2010-2012 GT500 Sprung Hub RXT StreetTwin Disc Clutch Kit (Clutch Only) [6975-07] : Lethal Performance, Performance parts for Ford Mustangs
Up until now if you wanted to run a Mcleod RXT on your 2010+ GT500 you'd have to switch out your 2010+ slave cylinder for an 07-09 version. Not only that you'd need to purchase a new flywheel as well.
However Mcleod just released a new setup specific for the 2010-2012 GT500's that not only works with the stock 2010+ slave cylinder but also works with your stock flywheel. Even if you burnt up your stock clutch your stock flywheel will work with this setup. That's because this new setup from Mcleod comes with a new friction adapter plate that bolts to the stock flywheel. In addition to that the new Mcleod setup uses sprung hub discs which are designed to give smoother engagement and better driveability on the street. The new setup also features a thicker floater plate which will prevent warping for those higher HP/Racing applications.
These new setups are in stock and ready to ship here at Lethal Performance. If you have any other questions or need assistance placing an order please feel free to give us a call. 877-2LETHAL
Thanks, Jared
Boostaddict is offline
Old 02-28-2012, 03:56 PM
adidasUNT8
adidasUNT8's Avatar
So I had a clutch/flywheel TSB performed a few months ago for my 09, and to my knowledge they replaced everything with the 2010 parts for the most part. Does this mean that this new set-up would be the one to go with?
adidasUNT8 is offline
Old 03-13-2012, 10:47 PM
Boostaddict
Former Sponsor
If you have the 2010 stock setup in your car then the new Mcleod Sprung Hub setup I mentioned above will work perfect with it. You'll re-use the stock flywheel and slave cylinder with it.
If you have any other questions please let me know.
Thanks, Jared
baddog671
07-26-2016 01:20 PM
Bokeo
10-10-2015 08:28 PM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: NEW: Mcleod Sprung Hub RXT Setup for 2010+ GT500's
