Loud creaking from the front
There is a loud creaking noise coming from my front end when I go over speed bumps, mainly when its cold out. I have steeda sport springs and Koni dampers. I used to also have camber bolts but i changed to Maximum Motorsports caster camber plates hoping that would fix it, but it didnt, it may actually be worse now. I think it sounds like rubber compressing from the spring or rubbing on the spring. Is there any way to completely eliminate the rubber parts from the front suspension, or does anyone know of a solution? I cant stand the sound and i really want to fix it, I may change back to stock springs if necessary.
Anyone else experience this? Any known sure solutions?
KingRando
10-02-2015 08:06 AM
