427 Engine - MustangForums.com
Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Old 07-18-2006, 07:01 PM   #1
04Mach1DD
Default 427 Engine
Shop just got a 427R Engine in today, then the boss comes in and tells us he wants it to fit in a new mustang. Has anyone ever done a 427 swap before? which tranny would be best to mach up for now, which tranny to use? any info would be appreciated. A ****-load of stuff will have to be done, everything will have to handle 550hp at least.
04Mach1DD is offline   Reply With Quote
Old 07-19-2006, 11:16 AM   #2
4Stangs
Default RE: 427 Engine
Is that a 427 big Block or a 427 Stroker based on a 9.5inch 351W block?
4Stangs is offline   Reply With Quote
Old 07-19-2006, 11:24 PM   #3
04Mach1DD
It would be a big block
Old 07-19-2006, 11:57 PM   #4
69FECoupe
According to this Roush information, it's a Windsor based stroker, not an FE big block. http://www.roushperf.com/pdfs/427R_E...tion_Sheet.pdf
69FECoupe is offline   Reply With Quote
Old 07-21-2006, 10:37 AM   #5
4Stangs
I think I'm done here. The guy doesn't even know the difference between a stroker (Dart Racing) sm. block and a classic Ford Big Block. I smell something...[sm=WTFsgign.gif]
Old 07-21-2006, 10:58 AM   #6
randy78045
The 351W is a Windsor class engine. It is made on the same factory line as our beloved 5.0. However, the 351 posseses several qualities that make it a desirable block for an engine buildup. The advantages of using a 351W vs a 5.0 (302):
Obviously, you get an extra 49 cubic inches of displacement. As the saying goes, there is no replacement for displacement. Second, the webbing in the lower half of the block is thicker, making the block stronger. Third, the crank has bigger main and rods journals, making the cranks more durable than their 302 counterparts.
FACTS: What you need to know/consider when you swap a 351W into a Fox3 platform chassis:
The 351 block is very similar to the 302. That means that almost all parts swap between a 302 and a 351. This includes: Heads, cam, lifters, timing chain, timing chain cover, water pump, engine mounts, and all sorts of other stuff. The bellhousing bolt pattern is the same as a 302, so all trannies that bolt to a 302 will bolt to a 351. However, there are some differences in the 351 that necessitate new parts:
1) The oil pan is different. Motorsports carries one. You can also get an oil pan of of an early eighties LTD Crown Vic. If you go the junkyard route, remember you also need a oil pan pickup tube, and a special main bolt that the pickup attaches to. The FMS pan is a pretty good deal, and if you shop around, you can get one for under $100, which comes with the dipstick, bolt, and pickup tube.
2) The internal balance of a 351W is the same as pre-81 302's (28.2 oz). The 5.0 HO has a 50 oz. unbalance, which means you cannot use the flexplate/flywheel or the harmanic balancer off of an HO engine. You have to get the correct pieces from a dealer/junkyard.
3) The deck height is higher, which means you need a different intake, since the 351W intake is wider. A 5.0 Upper will bolt to a 351W lower.
4) Also, a higher deck height means that the accessory bracket will need to be replaced. FMS sells the new bracket for about $50.
5) The higher deck height means the headers sit up higher than in a 302 powered Mustang. A special set is required for a 351.
6) A 351W will in all likelyhood not clear the stock hood. You will need a cowl hood for your car.
7) The distributor has a fatter shaft. You can obtain one from a 351W powered FI truck (if you are using FI) or any late 70's/early 80's car using the 351W and a Duraspark system if you are going to build a non-efi car.
Those are the major differences. As you can see, for about $1000 you can put a 351W in your Mustang. This is cheaper than a stroker, plus you wind up with a more reliable engine.
Tips: There are several things to look out for to ensure that your swap to a 351W is easier and more successful. They are as follows:
1) A high volume oil pump WILL NOT clear the FMS pan. If you want to run an HV pump, you must either modify the pan, or buy a Canton or similar pan, for many dollars more. The modifications just include cutting down the front drain bolt, and welding on a corner to the pan to clear the pump housing.
2) Get new motor mounts. If your mounts are questionable already, the additional weight of the 351W will make them fail in a hurry. I recommend the 87-93 convertable mounts, which will work in any 79-93 Mustang.
randy78045 is offline   Reply With Quote
Old 07-21-2006, 11:17 AM   #7
4Stangs
427 (351W with a 4.17 Stroke and 4.030-4.060 bore).
The post by Randy 78045 describes installation into a fox chassis. Not sure what 04Mach meant by a "new" mustang:
"...boss comes in and tells us he wants it to fit in a new mustang."
Old 07-21-2006, 01:31 PM   #8
69FECoupe
Ditto, that's why I mentioned that the information was from Roush Racing's web site. Call me crazy but I would think that someone who works for Roush should know the difference beween a Windsor and an FE.
Old 07-21-2006, 02:45 PM   #9
4Stangs
Quote:
ORIGINAL: 69FECoupe
ok...You're crazy.[sm=insomnia.gif] Ha.
Yea, i wonder about 04Mach sometimes...don't want to offend him but there seems to be a lot of [sm=bs.gif] in a few of his posts. I'm sure he's a nice guy though...
Now you can call ME crazy, but it seems he's still learnin'.
Old 07-21-2006, 05:00 PM   #10
S281 E
lol...
S281 E is offline   Reply With Quote
2005 Mustang - Transmission rattle and slippage/stuttering AmericanMuscle4.6GT 2005-2014 Mustangs 7 11-10-2015 02:06 PM
whats needed to swap a 4.6L into ratrod rksnow1 Motor Swap Section 0 09-14-2015 08:46 PM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 12:08 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 07:30 PM
V6 Engine Ticking Nick Oliver V6 S197 General Discussion 2 09-05-2015 10:34 AM
06, 427, bill, boss, engine, mach, motor, mustang, tally
