Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Dead Battery 2006 Saleen S/C Again!!
Old 11-14-2007, 02:35 AM
Pony on
Pony on's Avatar
Default RE: Dead Battery 2006 Saleen S/C Again!!
Check your ground straps. A quick check to seeif this your problem, when it doesn't start, use a jumper cable from the batterys neg. to agood chasis ground. If it starts up you have a bad ground strap connection to chasis, if not then you have an open ground that is slowly draining your battery. Aftermarket alarms are the most common open ground causes. Or as Amy mentioned it could be the ground to your headlights. Check all areas that Saleen removed grounds for work and insure good frame contact.Not Ford related in my opinion.
Pony on is offline
Old 11-14-2007, 04:43 AM
tmiles
tmiles's Avatar
Mine is killing the battery also here lately. I noticed after the second time that the clock on the radio is staying lit up. The radio has not been on in months. I dont drive it far enough to turn it on.
tmiles is offline
Old 11-14-2007, 08:30 AM
Bob D.
Bob D.'s Avatar
ORIGINAL: Pony on
Actually there are plenty of facory-stock Ford Mustangs with battery drain related to theShaker stereo system--in fact,I became aware of the radio as a possible culprit from a "regular" Mustang site and my dealer had only seenthe problemin non-Saleen cars. There may be some ground issues caused by work done by Saleen, but thereis definitely a Ford issue out there too. Whatever the cause, however, your advice is greatforthose whoneed to troubleshoot further to solve their battery drain issue.
Bob D. is offline
Old 11-14-2007, 10:20 AM
AmyVCTexas
AmyVCTexas's Avatar
ORIGINAL: tmiles
Oy! You need to get out more! They're more fun when they're moving, tmiles. [8D]
AmyVCTexas is offline
Old 11-14-2007, 03:30 PM
Jonsey
Jonsey's Avatar
I have an aftermarket alarm and GPS tracking module. Could this drain it in 2 weeks?.
Jonsey is offline
Old 11-14-2007, 03:40 PM
281sc060777
281sc060777's Avatar
Am I to understand that there is no actual fix?? If I bring it to a dealer and explain to them that the radio has to be turned off prior to shutting down the engine will they know what to fix? Obviouslyif a new radio causes the same issue there must be a wiring problem within the harnass....I plan on taking it in so I will keep you all posted....Thanks for all the info!!
281sc060777 is offline
Old 11-15-2007, 02:38 AM
Pony on
Pony on's Avatar
Your servicing dealer will be able to isolate the cause, tell them to look for a weak or open ground.
It's gonna be okay, I think[sm=smiley2.gif]
Pony on is offline
Old 11-15-2007, 09:25 AM
froman6
froman6's Avatar
Same here, mine was dying until I started turning of my radio (Shaker 1000). No issues since.
froman6 is offline
Old 11-16-2007, 07:51 AM
svfetter
svfetter's Avatar
Gentlemen,
There have been numerous posts on this previously and while the Shaker issue is valid there is no real fix for this issue. As stated on other posts by those more knowledgeable than myself - There is a constant draw on the battery with virtually all cars with the anti theif system. If you let these cars set for an extended period of time be prepaired for the battery issue. My limit on my new 427 is about 3 weeks. I have a 2000 Expedition that will do the same thing if let sit for a while without starting and driving. So it is not just isolated to Mustangs. Why some seem to be more sensative than others - Who Knows? I know I will charge my battery on a regular basis during the winter.
svfetter is offline
Old 11-16-2007, 08:06 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
ORIGINAL: svfetter
Gentlemen & ladies (please) ,
.....I will charge my battery on a regular basis during the winter.
..... me too [sm=gears.gif]
Jazzer The Cat is offline
Quick Reply: Dead Battery 2006 Saleen S/C Again!!
