Go Back   MustangForums.com > Ford Mustang Tech > Saleen, Roush and Boss Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-07-2008, 08:21 PM   #11
JimIII@JDM
Default RE: Just ordered my JDM kit..
actually it isnt, i can get a link of the saleen instructions.
Saleen has been using theirs since 05 when the first E cars came out, nearly two years before the shelbys hit the market.
Ford had the twin pump design and driver modules available to the public. So Saleen bought them and made their own harness. Saleen like the general public could not get the Ford harness. Ford wanted them for all their production shelbys. After they met quota the ford racing GT500 fuel system was released. We actually had the Saleen fuel system on the market almost 1 full year before the Ford Racing hit.
To me the Saleen harness is a cleaner, neater install. It has you run the wiring from the driver module, to the fuel pumps, to the inertia switch, then to the fuse panel box. The Ford racing system does not tie into the inertia switch which is only bad incase of a roll over. Also the wiring harnesses are different and you actually have to run wires up both sides of the vehicle on the Ford racing system and then on the Saleen system its just up the driverside of your vehicle. The only thing that means is that you are removing less interior panels. The harness is also less bulky than the ford racing system so it fits better behind the trim panels.
Both however perform the exact same job, but the do install differently.
JimIII
Thanks for the order Mike! great speaking with you today!
JimIII@JDM is offline   Reply With Quote
Old 04-07-2008, 09:19 PM   #12
unclemilti
Vehicle: 2006 Saleen 281SC
Quote:
ORIGINAL: JimIII@JDM
JimIII
I was talking about the fuel pump installation.
__________________
2006 Black SC281 #1113
HIDS
3.73
Chrome rim upgrade
JDM 550 upgrade
2004 Cobra
Black/Graphite
Amazon tuned
unclemilti is offline   Reply With Quote
Old 04-08-2008, 01:57 AM   #13
05HOTROD
Since we're on the subject of JDM, and the 3.4 pulley,,,, I just ordered a kit too, Well sorta........ I'm a little confused. I currently have the saleen 475 kit and purchased a tune and a 3.4 pulley. JDM said all I need to do is swap out the pulley and download the new tune and do the vacuum lines and I'm done.
Don't I need a new belt? should I have gone 3.6 first? I asked JDM these questions and they said that I would be going from a 3.6 to a 3.4 and the belt would still be ok. After reading and searching threads, I realized the 475 saleen kit pulley is a 3.8 not 3.6 like JDM said.
05HOTROD is offline   Reply With Quote
Old 04-08-2008, 09:56 AM   #14
desant89
Quote:
ORIGINAL: 05HOTROD
I think it depends what you asked for from JDM. I seen people Say Brenspeed uses or used the same belt for multiple pulleys. If you were moving only one step, I am assuming JDM figured it will work fine, and it proabaly would.
What did you ask for? Are you trying to go to JDM's stage II? Did you just tell them you wanted to make some more power?
Here is the JDM stage II contenets:
450RWHP!!! Everything you need to make your 2005-2007 Mustang move! Saleen / JDM Supercharger Stage 2 Package Includes:
• Saleen S/C
• Tuner
• Air Kit
• 90mm Mass Air
• Mass Air Harness
• 39 LB. Injectors
• 3.40 Upper Pulley
• K061075 Gates Belt
• Vaccum Line Kit
• Saleen Extreme Inlet Tube
• Autolite Spark Plugs
• Saleen Fuel System = GT500 twin pump
desant89 is offline   Reply With Quote
Old 04-08-2008, 10:10 AM   #15
HaneyMotorsport.Com
Premium Sponsor
HaneyMotorsport.Com's Avatar
Vehicle: 07' Mustang GT Supercharged
With the 3.4 pulley....gates belts KO61075. Just to let you know, you need to remove the alt. to install the new belt.
Casey
__________________
HaneyMotorsport.Com is offline   Reply With Quote
Old 04-08-2008, 02:54 PM   #16
05HOTROD
I asked for more hp (425rwhp range), So he set me up with 3.4 pulley, vacuum kit, new tune. I can't see what my belt number is on my car now. I hope I can use the same belt for the 3.4 pulley.
Again, I have the 475HP(385rwhp) kit on now that saleen sells.
Old 04-08-2008, 04:25 PM   #17
eolson
eolson's Avatar
How does Saleen figure that 385rwhp is 475. Hmmmmmmmmmm. Erik
__________________
06' Mustang GT premium pkg, Saleen SC with JDM kit with 3.2 pulley, 474rwhp, 452tk (upgraded Saleen intercooler), dual fuel pump. Complete Saleen, Steeda, H&R suspension upgrades, Techco watts link, Borla exhaust 9,10x18 chrome bullitt wheels, 285/40/18 & 255/45/18 Nitto 555 tires. Powerslot rotors, ss lines,ABS pads New car scent air freshener.
eolson is offline   Reply With Quote
Old 04-08-2008, 04:36 PM   #18
HaneyMotorsport.Com
Premium Sponsor
3.87 pulley to 3.4 pulley = BELT SLIPPING
Casey
__________________
Old 04-08-2008, 05:31 PM   #19
JimIII@JDM
Quote:
ORIGINAL: HaneyMotorsport.Com
Casey
Preach it my brother
I dont know who you spoke with 05HOTROD but with a 3.87 pulley its a 1080 belt and with the 3.4 its a 1075 so thats the one you need. The 3.6 pulley will use a 1080 belt however.
JimIII
Old 04-08-2008, 06:18 PM   #20
06Saleen3V
3.87 pulley to 3.4 pulley = VERY BAD BELT SLIPPING
Casey
fixed . Your right Casey. Belt sizes are very crucial when swapping pulleys
__________________
488rwhp @ 6.5psi
Techco FTMFW!
06Saleen3V is offline   Reply With Quote
belt, gates, ko61075
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
