Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Cams for S281SC
Old 05-07-2008, 01:11 PM
lujandj
lujandj's Avatar
Default Cams for S281SC
Hi Fellas,
Quick question here. I have a 2001 S281SC with series II blower. I want to upgrade the cams for more power/torque. Do any of you guys know of some good cams that will work with the Saleen motor/computer setup? Or should I be doing a Chicane pulley upgrade and re-turne instead? Which upgrade do you think would give me more low end power and torque? I have 3:73s, trick-flow girdle, 75mm TB, KN FIPK, SC belt pulley tensioner, FRPPaluminum driveshaft,MSD coils, NGK plugs, Lighting SuperTank, Canton Coolant Tank, Lighting double pass heat exchanger, MGW shifter, Steeda aluminum lower control arms, Koni single adjustables, Pypes Hiflo catted X-pipe,Cobra Brakes and Nitto rubbers and the standard Saleen goodies. Thanks for all your input.
Dave
"SicSaleen"
lujandj is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Cams for S281SC
