authentic saleen rims
#51
RE: authentic saleen rims
ORIGINAL: 06Saleen3V
No confusion at all Eric. I know the difference between the two. I am running 305's on a 10" rim and they work perfectly.
Jazzer-Jackin'
EDIT: how exactly does a cat eat words? Last time I did that I was in-consonant for days [8D]
#55
So for the record, anyone, what are the fronts that are close enough in height to match the 305's 28.4 height??? 275/35/20 still at 27.7? That's a noticable difference isn't it? Erik
#56
28.4' is absolutely HUGE!
I wouldn't worry about the fronts as much. The speedo does not work off of them, and will be hard pressed to find (let alone FIT) a tire that diameter under the fronts. I don't know why you would notice any difference, have you ever seen the Prowler[8D]
Jazzer
Jazzer
#57
Good point Jazz, I was just curiuos how Saleen will set their standard sale tires, since their entire SC line will be more powerful, I would imagine that those sizes would be better traction for all SC cars past 420rwhp with 20" wheels. It compansates for the slightly less traction 20's get compared to 18's.
I would imagine that someone with 20's with 305/35/20's and 3:73 gears would be about the same with grip and speed as someone with 285/40/18's and a 3:55 gear ratio as myself, from what I understand. Erik
#58
ORIGINAL: Jazzer The Cat
Jazzer
Jazzer
Its actually slightly smaller height-wise then the 275/40's that used to be n the rear.
mungodrums
09-28-2015 10:54 PM
