ALL SALEEN PJ OWNERS????
Quick question for all the other PJ owners out there........have any of you had any problems with the molded plastic piece around the shaker opening in the hood CRACKING??? Mine has a couple cracks in it I'm assuming from the heat and/or vibration of the engine with only 2500 miles on it. Just curious. I have a new piece on order so hopefully it doesn't do the same thing.
Also, mine seems to be prone to detonation (I've tried Mobil, Shell, Valero) and it still does it at higher RPM (around 5k)........I heard something about there being a TSB on the Mustang ignition coil packs, so maybe I have the bad ones......whatcha think??
Thanks in advance for any help and info!!
C.J.
PJ #472
C.J.
PJ #472
I'll be trying Chevron at my next fill up...............thanks for the info and we'll see what happens. Saleen also recommended to disconnect the battery so the computer could reset to neutral. They said that if I got ahold of some bad gas, the computer would remember this and still run like crap even after putting good gas in........I'll give it a shot with the battery disco and Chevron and see what's up! As far as the trim cracks...........not a whole lot to do about that one except just hope the new piece works out!
