Saleen fog light bulbs size?
I'm talking about the lights beside the headlights that look like these.
there is a clear bulb and an amber bulb next to the headlights in a circular housing, the clear bulb is the one i'm talking about.
I tried typing in everything that mikebna said it was line by line but nothing came up.
I'm looking for something like "it's a 4057 bulb". (it's not a 4057 fyi)
Ahh the 'sidelight' bulb as called here over the pond, I have no idea if the code will be the same over there but here it is a '501' fitment, your local BMW dealer should have them ob the shelf.
I had my front fascia off back in 2005 but never noted the numbers. Also, I THOUGHT there was only one bulb in that housing....the housing is a split lense making it look like half clear and half amber - again, going from memory I THOUGHT. I could be wrong.
Two bulbs Jason, one for turn signal (21w) one for side/marker light (5w)
There are 2 bulbs in the front of the turn signal housing, one is clear, one is orange/yellow.
Clear-http://www.bimmerspecialist.com/usa/...ls/88100141179
Orange/yellow-www.bimmerspecialist.com/usa/parts/product_details/88100141178
I replaced my right front turn assembly after cracking a lense. Saleen sent me a new one and it had the bulbs already in it so now I have an extra set.
Here is the link to the right and left front turn assemblies-
right
www.bimmerspecialist.com/usa/parts/product_details/63137165862
left
www.bimmerspecialist.com/usa/parts/product_details/63137165861
keep in mind that Saleen modifies the one side with the two holes in it by cutting off the outside hole leaving one hole on one side and two on the other side of the bracket. If you have to replace one just compare them and you'll see. The mounting screws are not included but can be removed and inserted into the new one.
I hope this helps, maybe Jason can sticky it for future references
Saleen sells the whole assembly for 29.99 plus shipping direct from their site but they do not sell the bulbs separtely.
mike
right
left
mike
