Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
Cold Startup RPM's too high???
Old 01-14-2009, 11:07 AM
esanger
esanger's Avatar
Default Cold Startup RPM's too high???
It's only about 35 deg here in Alabama in the morning and I decided to start up the car. Upon startup it immediately revved up to about 2200 rpms and then slowly settled down to around 1K. 2200 seems a little high for initial rpms on a cold engine. I would think that revving that high when everything is that cold would put unnecessary stress on the engine..
Thoughts??
esanger is offline
Old 01-14-2009, 11:34 AM
sftdyna
sftdyna's Avatar
Thoughts??
myself and many others have gone threw this with new tunes, i had jim sr readjust my tune so now on cold start it goes to about 1500 for a split second and come right down, my concern was the same as yours and it seemed it took some time for jim sr to make it right!! but im sure he has got it down now!! also it isnt just jdm, others have had simular results with other tuners.
sftdyna is offline
Old 01-14-2009, 12:36 PM
unclemilti
unclemilti's Avatar
Thoughts??
Mine does the same thing, too.
Its absolutely unecessary added strain and wear on the motor.
I called JDM, and was told "its normal", when obviously if sft's tune was changed, its not normal.
All my other vehicles rev to approx 1500 rpms when cold.
Eric..we may need to call JDM and ask that our tunes be revised.
unclemilti is offline
Old 01-14-2009, 01:09 PM
sftdyna
sftdyna's Avatar
mine would go to 2000 rpm and stay there for a second or two before it dropped, the other day it was 15 degress outside and i needed to get my quad out so i had to start my E!! i would not have even started it had the tune not been corrected, especially since jim sr is dead against using 5-20 mobil 1 and claims it throws off the vct because its to thin, so now on his recomendation im using a motorcraft semi syn thats 10 - 30 and would definately be thicker and harder to pump up on such a cold start. speak with sr directly because sometimes you can receive the wrong info when it goes threw a few people.
sftdyna is offline
Old 01-14-2009, 02:05 PM
unclemilti
unclemilti's Avatar
I have noticed that....
Old 01-14-2009, 07:22 PM
06Saleen3V
06Saleen3V's Avatar
If its only at 2200 for a second, it is fine...the motor is just very cold...now, if it stayed at that rpm for more than 5 seconds, you would have a problem
06Saleen3V is offline
Old 01-14-2009, 08:03 PM
sftdyna
sftdyna's Avatar
i think it also has to do with the fact that our cars didnt do it before the tune!! and maybe just maybe some of us would like it to not do it after the tune!!! my car hung at 2000 for a sec or two but still took its time coming down, 2200 is even worse!! worse then that is getting the wrong info about it being normal. contact sr he will make it right, he did for me.
sftdyna is offline
Old 01-14-2009, 08:34 PM
unclemilti
unclemilti's Avatar
i think it also has to do with the fact that our cars didnt do it before the tune!! .
Yeah, I think that is my main issue with it...it didn't do that until this last tune...
Old 01-15-2009, 12:21 PM
esanger
esanger's Avatar
Spoke with Jim Sr. this morning. JDM is going to tweek my Stage II tune and send me a new one that will alleviate the issue.
esanger is offline
Old 01-15-2009, 12:58 PM
sftdyna
sftdyna's Avatar
also spoke with sr on this topic and he was actually waiting to address the issue with all those concerned.
sftdyna is offline
Quick Reply: Cold Startup RPM's too high???
