Quote:
Originally Posted by LilRoush
That year S3 should runs 12's all day right out of the box. Just remember that the suspension is set up for corning, not launching.
Those mods will put you at roughly 380ish at the wheels assuming your motor and tranny are in good shape.
I'm not sure about 380ish at the wheel...
It's rated 360 from the factory at the flywheel which would equate to around 295ish to the wheels. The pulley should net you around 30 and the LT's and the intake should get you another 25. I'd argue a little closer to 350ish.
Still a sweet car. I'd say high 12's depending on the driver on stock tires.
*EDIT* That's an
awesome thread, smoke! Thanks for posting it!!!
__________________
2002 S281SC Saleen Mustang Speedster
66mm Chicane Pulley
SVT Focus Fuel Pump
3.73 gears
NGK spark plugs
PIAA fog lights
SCT tune
LFP Heat Exchanger and Supertank
Tork Tech Intake w/ oval single blade TB
Chicane Intercooler
42lb Ford Racing Injectors
90mm Lightning MAF
