Is the lfp supertank a battery relocation one, Or does it mount where the stock one goes? I have the Canton expansion tank for the radiator and I want to get the supercharger expansion tank, looks sharp.
It mounts close to where the stock one is. It sits a little farther back in the engine bay....but in the same general area.
Here's a picture of mine (powdercoated black):
By the way, Paulie......what's the update on your mods?? Did you get them installed yet?
The website finally worked and I took a look at the products, Theres two heat exchangers I noticed for the lightnings. Does it matter that much more to go with the double pass over the single? It was only like a $60 difference for the double. How much fabrication is there to fit in on the saleen?
You will have to call them and ask for the H/E and Supertank that they have for the Saleen don't know why they are not on the website.Install is not too hard the brackets are not predrilled so you have to match them to the old hole location and redrill. All the AN fittings are in the same places too.I see that you have a 02 Saleen your temp sensor is in the tank the new tank from LFP does not have any provisions for that you will have to somebody fab that for you.
Reason: Wanted at add some more info
+1. Know that you'll lose your intercooler H2O gauge when you install the supertank on a 2002 or earlier car. My tech has been looking for a sensor that fits the thread he had welded in and still supports the 60-200 range.
